Got my new GMC HD!
antig24
Congrats Mike! I know you've benn waiting a LOOOOONNNNGGGGGG time!
NICE! I especially like the white. All you need are some white "GM-TRUCKS.COM" stickers in the back window! hehe
BTW,
Does it feel much longer than a ext.cab?
Guys, this truck is hard to get out of. I love driving it. Can't begin to tell you how nice this thing runs. The transmission is by far the best trans in this size truck on the road. It has shifting characteristics the competition dreams of. When you're going down hills in a residential area, you don't have to continually hit the brakes. The trans will not upshift in a coast. It also tends to remain in a specific gear unless you throttle up. Then it upshifts as your speed increases. I love it!
The white flares are factory. GM mentioned they would be white in the interim model year production. If they came black, I would have had them painted.
I like the way all the electrical stuff is set up, like it has intelligence. Lights come on, radio stays on after you turn the truck off, until you open the door, if you leave your turn signal on too long it signals you. I pushed the dome override button twice and the lights go out. Real nice setup. I don’t know why people ask about overriding this stuff. Suites me perfect.
Roofer, it doesn't feel like a bus. It has a really good turning radius compared to the '93 ext cab 8' bed I used to own.
Thanks everybody.
BTW: I added afew more pics here...
http://members-http-2.rwc1.sfba.home.net/h...rs/duramax/gmc/
(Edited by dmax at 8:35 am on April 25, 2001)
I just noticed, I really like the license plate! Great pic of the price sticker also, most I can't even read, but yours is real clear.
Later
Very nice truck, wish I could get one.
You must have quite a job.  That ?K made my mouth drop open.  I knew they were getting high, but that is unreal.
I ended up paying ?,000. Remember, it's a Crew Cab Diesel, 4x4. pretty much loaded.
I agree though.... still too much doe. Paid more for it  than my first two houses.
mike
mike
Yeah, My Mom and Grandma always tell me how you could get a '69 Mustang for ?,000 back in 1969.
Everytime they tell me that it makes me determined to build a time-machine. LOL
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
