FINALLY!
chevy4x4trucks
well my ? in the PM was if i could use a slightly modified version of the photo gallery that on yout site on mine.  there is a mock up of what it will look like on my site minus peoples trucks on my site
That looks like a pretty cool Ranger there. I have owned two Rangers in the past. First was a 1998 Red 4X4 X-Cab 4.0L. I bought it in when stationed in Everett, WA. At the time, I had a 1996 Nissan pick-up and got stuck in my apartment complex when it snowed, so I got the 4X4. I'm not an off-road enthusiast, so when I got stationed in Pascagoula, MS. I traded the 98 for a 2000 Ranger Std Cab 4X2 4.0L. I was enjoying that truck, but it developed a cold engine knock and then started making noises at all times. Some refer to it as "marbleing" or the sound of marbles rattling in a can. Took it to a dealer and of course they couldn't hear anything. Many Rangers with the 4.0L OHV report having this condition and say it doesn't affect performance, but it really bothered me. So, I traded the 2000 Ranger in on the 2002 GMC and I am much much happier now. I now have classic V-8 power and a quiet engine and get only about 1 mpg less than I did with the V-6. I had thought about the F-150 but they have a problem with the doors cracking where the window frame meets the door. I have actually seen a couple of these. And, I found in side by side comparisons the GM trucks come out on top.
So, get off the fence Paco and go with GM trucks all the way. Put a nice SSR or something on there.
Yea, I know Paco. They went from the 4.0L OHV to a 4.0L SOHC. People still complain about engine noise. And besides, for only a couple grand more you can get a whole world of difference better truck.
I'm not knocking the Ranger, I loved the ones I had, except for the engines "problems". It's just that I have a much better truck now. The only thing I miss about the Ranger is the coin and cup holders were handier than in the GMC. I had a center console in the Ranger and now the split seat in the GMC. If I had a center console in the GMC, I might not even miss that.
I was a member of all the Ranger forums/boards and now I've looked at all the GM boards. It just seems that overall, there are alot more problems with trucks on those other boards.
Atleast you're an All-American fan  :)
The site looks good there paco..
I definately agree that the html sites are way better to build with than the homestead type ones..
Keep up the great work!!
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
    • Looking for a clean way to add serious lighting to your 2019+ GMC Sierra 1500? Our M&R Automotive 40" SLIM Light Bar Kit was engineered to deliver maximum performance while maintaining a factory-inspired appearance.   Features: • Designed specifically for 2019+ GMC Sierra 1500 models • High-output 40" SLIM LED light bar • Clean, integrated grille-mounted design • No cutting or drilling required • Bolt-on installation using vehicle-specific brackets • OEM-style fit and finish   Whether you're hitting the trails, exploring backroads, or need additional visibility off-road, this kit provides powerful illumination without compromising the look of your truck.   For product videos, light output demonstrations, and installation content, check out our YouTube channel:   https://www.youtube.com/channel/UC3lutWP54fkXBl3iFLDJR-A Have questions about fitment or installation? We'd be happy to help.
    • $3.63 today. Inching down. Plenty still over $4.20
