Towing With Level Ride, What To Expect
one sweet ride!! my mom has an 02 autoride lt, and we hook up the boat and load her with gear and fill her with 7 people and she sits past level... i am extremely jealous of her, i want it on my new z71 so bad!!!
good luck! hope she rides like a charm!
steve :D
The autoride on the 3/4 ton does not do load-levelling, it only adjusts the damping on the shocks.
But at 4400 lbs, unless that trailer is very front-heavy, I don't think you'll see excessive sag. My 8K trailer does cause some sag on my '04 Suburban, but I use load-levelling bars which do a great job.
The tongue weight is only about 300 lbs?? It doesn't sag my 1/2 Silverado I know that.
I do use a WD hitch, wouldn't tow without one.
I just didn't know what to expect the Burb to do, I don't know what "Level Ride" is supposed to feel like or do different from not having it..
yeah auto ride will just add more air to your shocks and bring it up to a level ride, you wont feel anything different while towing, no under/over steering and no uncomfortable sag, its gonna feel extremely comfortable, when my mom bought her truck brand new off the lot, the guy promised this " floating on air" sensation, being the two jokesters me and my dad really are we looked at each other and :flag: rolled our eyes, but then we got in... and we were amazed, it truly does feel great! tows like a dream, i like it so much i'd like to buy the same thing for my 1/2 ton z71... everytime i hear her compressor fill em up it makes me :banghead:
good luck!! steve :driving:
You will love towing with it. Read the manual about how to use an equalizer hitch with it. My YD with Autoride tows so much better than my Sierra Denali you can't even compare them. There is no hitch bounce with it, even on a really rough road you can't tell you are towing.
Dan
I forgot to ask if you have stability control? This adds another item thats is kind of neat for towing, it stiffens up the shocks while turning and adjusts the air ride, you can see the voltmeter drop when the system is working in turns.
Dan
Dan
no stability control, but it does have auto 4X4, thats not the same, right?
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
