O2 Sensor
When they go out or some people change them between 75K and 100K becasue they can get lazy and never set a code.
No, it is not hard to do but you will need a special made socket with the slot for the wire down the side. They are not expensive.
No, the ones in front of the cats are different from the ones behind the cats.
You are the man with the answers, sweeeeett, I'll be changing those out at work tommorow Thanks
Yea, and about 50% of them are actually correct. :eek:
I try to help if I can but once it gets a little technical or deep, I have to refer those questions to the Prof Techs who reside here.
If you have 4-wheel drive the drivers side manifold O2 wiring harness will be a beotch!! The front driveshaft runs right next to the tranny and blocks you from getting at that one unless you have rubber arms.
As long as you can get to them from the side a wrech is fine. If you cannot and a socket is needed, you have to have one with the wire slot up the side.
I guess I am showing my age now. I have never seen an episode of SouthPark.
I think I've seen about 10 min of an episode when I was channel surfing late one night. 10 min. was about all I could take, it was total cr@p!
Then you need to see the episode where al gore is on a quest in search of "Manbearpig". I laughed so hard I was tearing up.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
