Tpms
mudcruiserman
Hey Guys, Newbie here. I have a NBS shortbox WT 2WD
I lowered it 4/6 with DJM kit. I added 20 inch SS wheels and it looks sharp
My question is:
Hello, I'm new to the forum. I have a NBS 07 silverado WT
I put 20 inch SS wheels on and now have the service tier pressure ststom message on the DIC
I seen other post about the RCDLR (remote control door lock receiver) also receiving the TPMS signals.
OK point is other post said this comes as a part which the tpms part has to be turned on
and once on it cannot be turned of by the dealer.
So instead of buying 4 new sensors I want to replace the RCDLR at 79 bucks
does anyone know has this worked?
My question is:
You're stuck with the TPMS on your truck. The RCDLR controls the TPMS, VATS, door locks, remote start and coffee warmer. The TPMS cannot be eliminated by tuning or a Tech 2. Add the tire sensors from your original 2007 NBS wheels to your custom wheels and be thankful you have such a good early disaster warning system installed. If the TPMS sensors do not work on your custom wheels, you'll be looking at that tire light on your dash a long time.
zoz
I don't want to detune it. I read on another post about someone who had a RCDLR that was not programmed when installed to communicate with the TPMS Sensors.
Further noted was the fact that when you buy a RCDLR/remote control door lock receiver that the TPMS function has to be programed by the dealer to make it work. As does its other functions.
My point is If I buy this part and dont have it turned on then it won't be looking for a signal hence no light.
I have no remote door openers and everything else is manual also.
I think if this works it would allow many of us to switch wheels and save on relearniing and cost of new sensors.
