Make My Truck Look Tougher
Grillguard and a winch. Taller/Wider tires.
Those Yo, Samity Sam mud flaps. :driving:
What size of tires? Aren't 285 just wider than a 265 or is it taller too?
If they are the same profile and rim diameter, the 285 will be wider and taller. Ex. 265/70R17 and 285/70R17
Check out this website, you can calculate your tire height, width, speedo difference, etc. http://www.miata.net/garage/tirecalc.html
It is. 285 is 285mm in width. The /#(example 285/75) is the aspect ratio of the tire sidewall height. The example being 75% of 285mm or 213.75mm. The higher the %ratio the taller the tire.
I hope you understand, as I am not the best teacher.
Go with an aggressive looking tread on the tire as well like a BF Goodrich T/A KO. IMO the tread pattern on that tire makes them look bigger and meaner.
Depending on the lift you could go even bigger, if you are in fact doing a lift.
