Bridgestone Dueler P26570r17 Tire Problems
rossn2
I'm looking for a GM Tech Service bulletin or notice regarding the 06 1500 series Silverado Z71 with factory Bridgestone Dueler P26570R17 problems.
Specifically, problems with customers complaining of out of balance, flat spots, shimmies, vehicle feeling like it's hopping down the road, etc.
Notice/Bulletin talks about: Tire Balance, rotation, wheel alignment, and tire replacement.
thanks
thanks
I don't know about any bulletins but back in May my dealer replaced my wife's 4 tires from premature tire wear. At 13,360 miles they were wearing out fast. A guy I work with has the same problem, went to a different dealer and they would not replace them.
Here's what I found and I don't want to retype the whole thing, just highlights. Don't remember what internet forum I pulled it from last year...
Subject: Bridgestone Dueler Product Information Update - keywords alignment blister front pressue rear tire virbration wear wheel #PIT3562B - (6/19/2006)
Models: 2004 -2006 Chevrolet Avalanche, Suburban, Tahoe
2004-2007 Chevrolet Silverado Classic
This PI has been updated to provide fix information. Please discard PIT3562A.
Condition/Concern: Bridgestone tire information update
Recommendations/Instructions; Custome concerns have been received realtive to vibration, flat spotting, wear, etc. on trucks equipped with P265/70R 17 Bridgestone Dueler A/T tires with TPC Spec # 2328..
There's more...abut I can't type it all.
I was having the E85 software update done yesterdady and the dealership told me to go to a Firestone dealer...go figure..
Are Bridgestone and Firestone the same company now? Our new tires are still Dueler A/T but they have a lot different tread. I am considering going to Sam's club tomorrow and get this same tire for my 2500HD in a 265/16/. It is a pretty good looking tread and I will be pulling my truck at four local fairs next month and they look like they will get better grip then the Bridgestone that they come thru from the factory.
I've taken the vehicle to local Firestone Dealer and they're gonna replace the tires. They were not aware of the Product Information Update until I showed it to them. So, they'll cover under warranty I have to pay for mileage use, but going to upgrade to the Dueler Revo tires in P26570R17 and it'll work out to around $83 a tire or so...
Not happy with GM service...Happy with Firestone Dealer!
  • 2 years later...
Can you provide any more information on the Product Information Update. Bridgestone says that it don't exist.
in my opinion..... if you have had trouble with your Bridgestone or Firestone tires (same tires, all made by the same company...) then just be glad you have not had a tread separation blowout at 70 mph.... get rid of them, forget any Product Bulletin or warranty.... suck it up, and just go buy some good quality aftermarket tires (BFG, Cooper, Toyo, Michelin, or whatever...)
these guys do not care about YOU or YOUR SAFETY ... they only care about themselves and putting the cheapest possible tire on OEM trucks that they can get away with.... generation after generation, Firestone is the brand that consistently has problem tires... frankly I don't know how they stay in business... they certainly don't get any of mine.
I suspect that your advise is right on. In talking to local tire shops they tell me case after case of Bridgestone tires wearing out the same way. I spent some time talking to a Bridgestond Factory rep and got nothing out of him. Pretty much they don't warrent much of anything on orginial tires.
After talking to a couple of Firestone shops and getting asked question like "can you prove you rotated as the manuel states" I don't know if they will warrenty tires even if they sold them.
Anyway I have thought of flipping them rim to rim and letting them wear out the other side for a while.
Thanks for the reply
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
