Deichler Posted July 22, 2007 Posted July 22, 2007 I was trying to take off my e-brake on my 02 Silverado, and the head of the screw broke off. I was wondering how about to get that out. Do I have to pull the axle shaft out or is there another way? Also can I run it with out the e-brake shoe in there? I was hoping to get a little feed back on this situation quickly!! I never used the e-brake and the shoe was what was giving me my squeaky/grinding noise and was wondering if I can run w/out the shoe for now? HELP!! Thanks in advance!!
Deichler Posted July 22, 2007 Author Posted July 22, 2007 Update: I took the shoe off. I cable tied the "wheel cylinder" together to keep it from coming apart. If I could please get some guidance on how to get the screw out I would greatly appreciate it. I didn't put much force on it and it snapped off. So I think it will prolly be a bear to get out. Thanks for ANY help anyone can give me.
Bish Posted July 22, 2007 Posted July 22, 2007 Update: I took the shoe off. I cable tied the "wheel cylinder" together to keep it from coming apart. If I could please get some guidance on how to get the screw out I would greatly appreciate it. I didn't put much force on it and it snapped off. So I think it will prolly be a bear to get out. Thanks for ANY help anyone can give me. Best bet would be to centerpunch, then drill a small hole in the center of the screw (what is left of it) and use a screw extractor. In case you don't know what a screw extractor is....it is reverse thread meaning counterclockwise tightens it. Use one small enough compared to the hole so it will dig in a little before tightening up. You should be able to back it out without too much effort. Spray a little penetrating oil on it before you start.
Deichler Posted July 22, 2007 Author Posted July 22, 2007 Update: I took the shoe off. I cable tied the "wheel cylinder" together to keep it from coming apart. If I could please get some guidance on how to get the screw out I would greatly appreciate it. I didn't put much force on it and it snapped off. So I think it will prolly be a bear to get out. Thanks for ANY help anyone can give me. Best bet would be to centerpunch, then drill a small hole in the center of the screw (what is left of it) and use a screw extractor. In case you don't know what a screw extractor is....it is reverse thread meaning counterclockwise tightens it. Use one small enough compared to the hole so it will dig in a little before tightening up. You should be able to back it out without too much effort. Spray a little penetrating oil on it before you start. Will I have to loosen up the axle flange? It is really awkward right now and I think it would be easier to take the flange off, or do you have a better idea? I have the drill bits and extractors, but I am wondering if I loosen the axle flange for the axle shaft if I will need to put in a new seal and bearing at the same time? If someone would know what I need to do I am sure I can do it.
Bish Posted July 23, 2007 Posted July 23, 2007 Update: I took the shoe off. I cable tied the "wheel cylinder" together to keep it from coming apart. If I could please get some guidance on how to get the screw out I would greatly appreciate it. I didn't put much force on it and it snapped off. So I think it will prolly be a bear to get out. Thanks for ANY help anyone can give me. Best bet would be to centerpunch, then drill a small hole in the center of the screw (what is left of it) and use a screw extractor. In case you don't know what a screw extractor is....it is reverse thread meaning counterclockwise tightens it. Use one small enough compared to the hole so it will dig in a little before tightening up. You should be able to back it out without too much effort. Spray a little penetrating oil on it before you start. Will I have to loosen up the axle flange? It is really awkward right now and I think it would be easier to take the flange off, or do you have a better idea? I have the drill bits and extractors, but I am wondering if I loosen the axle flange for the axle shaft if I will need to put in a new seal and bearing at the same time? If someone would know what I need to do I am sure I can do it. I forgot they were behind the mounting plate Best bet is to pull the axle. I did it when I replaced the backing plates that rusted to death. You have to open the rear diff, Unlock the pin-locking bolt and slide the pin partially out. That gives you access to the C-Clip on the end of the axle. Push the axle in, remove the c-clip and remove the axle. Pictures help and I had my Helms manual. I consider myself a better than average shade tree mechanic and it was fairly simple. I did both axles and the second side took 10 minutes compared to the4 5 minutes I took on the first. Lastly, the brake is really a "parking" brake. If you never use it and you are concerned about pulling the axle , just leave it then and hope you never need t o use it.
Deichler Posted July 23, 2007 Author Posted July 23, 2007 Update: I took the shoe off. I cable tied the "wheel cylinder" together to keep it from coming apart. If I could please get some guidance on how to get the screw out I would greatly appreciate it. I didn't put much force on it and it snapped off. So I think it will prolly be a bear to get out. Thanks for ANY help anyone can give me. Best bet would be to centerpunch, then drill a small hole in the center of the screw (what is left of it) and use a screw extractor. In case you don't know what a screw extractor is....it is reverse thread meaning counterclockwise tightens it. Use one small enough compared to the hole so it will dig in a little before tightening up. You should be able to back it out without too much effort. Spray a little penetrating oil on it before you start. Will I have to loosen up the axle flange? It is really awkward right now and I think it would be easier to take the flange off, or do you have a better idea? I have the drill bits and extractors, but I am wondering if I loosen the axle flange for the axle shaft if I will need to put in a new seal and bearing at the same time? If someone would know what I need to do I am sure I can do it. I forgot they were behind the mounting plate Best bet is to pull the axle. I did it when I replaced the backing plates that rusted to death. You have to open the rear diff, Unlock the pin-locking bolt and slide the pin partially out. That gives you access to the C-Clip on the end of the axle. Push the axle in, remove the c-clip and remove the axle. Pictures help and I had my Helms manual. I consider myself a better than average shade tree mechanic and it was fairly simple. I did both axles and the second side took 10 minutes compared to the4 5 minutes I took on the first. Lastly, the brake is really a "parking" brake. If you never use it and you are concerned about pulling the axle , just leave it then and hope you never need t o use it. Thanks for the info!! That helps me out a ton. I think for the time now I am going to leave it. I have the shoe out and the wheel cylinder for the e-brake is cable tied together so it stays in place. I hope it hold otherwise I may have to do something with it. On my 73 Ford I had the axles out on that 50 times and all you had to do was take out the 4 bolts and slide her out. This here sounds a bit more complicated. I would'nt mind doing it right now but I am reaching my yearly layoff, (3 weeks starting in mid August), and am really scrapped for cash. I am trying to get a couple months ahead on truck payments and something just always has to go to hell when you plan something. If I wouldn't have broke the focken bolt off I would have prolly replaced the shoe and be done with it, since it is an integral part to the operation I think I'll say piss on it and wait till after layoff, hopefully I'll have some cash to spend on it. Thanks alot everybody with my problem, sorry to right a novel, but I like to thank people who help me. Thanks!
Bish Posted July 23, 2007 Posted July 23, 2007 Forgot to mention my Tahoe has the G80 locker. If you have just an open diff, I believe pulling the axles is much more simple. Good Luck.
