Adding Amp To Nbs Factory Radio
want to add my amp to NBS factory non-bose radio (not buying my new nav/dvd head unit for a few months)
wondering if anyone knows an easy plug-n-play way to add preamp outputs to factory wiring? have a 2-ch line output converter.. just really didn't want to hack up the factory wiring for something i'll only use for a few months.
also, anyone know where i can get a factory audio wiring diagram- so if i do have to cut into the harness, i'll know which wire's are the speaker wires..?
thanks!
check crutchfield.com There are units that you can get that will reduce the signal to a usable signal for an amp. I forget what they are called, but crutchfield should also have wiring diagrams for the audio stuff.
thanks!
I just finished installing an amp in my NBS Extended Cab Silverado.
I Had to hack into a few wires but its not that bad.
-I removed the panel on the passenger side in front of the door and tapped into the yellow wire for a remote turn on.
-For the rear speaker wires all you have to do is remove the sil plates on both sides of the REAR. I removed the front sil plates and even though some of the wires match, they are not the same.
-left side yellow- brown+
-right side lt blue- dk blue+
The bass output on the stock stereo steadily goes down as volume goes up. My band-aid for this was to get a remote gain for my amp and run it to the front of the jumper seat. It sounds ok for now but it should sound better once I get the down firing sub box. I just have an old box sitting on the floor while I wait for the UPS guy to show up.
MTX and JL Audio both make signal processors to solve the declining bass problem but I'm not sure how I want to build my system right now so I just installed stuff I had laying around.
Hope this helps.
Erik
    250.3k
    RobbertClaus
    RobbertClaus
  • Who's Online   5 Members, 0 Anonymous, 508 Guests (See full list)
    • No I didn’t watch a video of a person who analyzes oil for a living explain general oil usage. For clarity I did ask my brothers one who runs our equipment business. The other who runs our old ROW business about oil usage. Nothing has changed since I retired. Their personal vehicles or work vehicles use no oil. Not enough to see on the oil checking device. Then I pondered. I like to ponder. In this extended oil changing world with oil change countdowns or lights. If engines used say a qt every 2500 miles or up to even 4000 miles. With oil changes reaching as high as 15000 miles. Normal for most people is eight to ten. Vehicles should potentially be seizing up all over the place. Especially in hilly terrain. Just how many people actually check their oil? Maybe 10 percent. Those are the people that probably change their oil early. I like to research used car listings. I have five favorite dealers I check. They all list carfax with their listing. It’s rare to see vehicles with anything but extended oil changes. Transmission service, forget about it. I’ve seen Honda and Toyota certified vehicles up to 100K miles and ten years old. With nothing but normal maintenance. Isn’t nice we all have different experiences and believe our way is the best. You certainly get backup for whatever you believe. Life would be boring otherwise.
    • Interesting rumor. Dealers near me have been tight-lipped so far, but if this reveal actually happens next week, I'm really hoping they finally give the HD a proper interior overhaul. The competition has been eating their lunch in the cabin department for a while now.
    • There are a few good takeaways in that video that pertain to this thread, certainly the possibility of the oil control rings having buildup, the fuel injectors and how clean or not that they are ending up affecting the pistons rings carbon buildup, and the fact that its normal up to a point for a given engine to use some oil, and that the oil quality that is being utilized is part of that ring clogging up issue as well.   I was talking with a neighbor yesterday who has a baby LZ0 duramax and he had bought it slightly used but it does consume some oil and he has switched over to 5W-30 Euro spec oil and in this case that never made a difference in consumption over the factory 0W-20 recommendation. He finds it uses a quart in about 3500 miles and as he goes a ways over that distance he adds oil to full and goes another 1000 miles or so and then changes oil and is typically at 40% or so left on the oil monitor at that point with his use case of quite a lot of highway miles and more limited in short run use. I don't know what other LZ0 engines are doing for oil consumption but that is what his is doing.
    • I dont care what Lake says. Goodnight.
    • Ok well I guess Lake disagrees with me on a few points. I call oil consumption pretty basic. Rudimentary. He calls it "really complicated." I think 1qt consumed in 3k miles is a lot. He says that's normal. In 22 minutes, he'll use his natural talent to explain oil consumption to anyone watching this video. He covers everything from obvious engine damage to how normally functioning healthy engines consume oil by design. Lake explicitly states how you drive will impact oil consumption.   Shut up and watch:
