My New Work Ride Yall
hey guys this is my new ride. Gm gave me a new 07 seirra with all kinds of goodies on it. i work for the accessory dist. installer wich does nothing but gm accessories but figured you guys could appreaciate these photos none the less
hopefully you all can get to these sorry i didnt know how to make a photo show up on here besides this insert thing at the top
cool it worked by the way anyone want that s10 i got to get rid of that d**n thing
ok sorry i know im adding to my own thing here but let me tell you what we put on
:gm tonneau cover (with gmc logo)
:gm 20" wheels 5 spoke wich is currently on back order,,lol
:gm chrome door handles
:gm chrome mirrow cap
:gm chrome grille (in gmc fashion)
:gm chrome bug sheild
:gm chrome fuel door
:gm stainless tube bars
:bed rug (also by gm but with gmc logo)
other than that,thats it....but a cool truck to ride around in they defently turn a heck of alot better than the old 800 series trucks. and get this its also got the 5.3 i thought i was getting a bottom of the line or welfare model but its nice.
yeah those things are pretty sweet so heres the rest of them wich you can also find on www.gmaccessorieszone.com and also all the prices as well. but to answer your question there like about 3300-3500 depending on who you talk to ...also at that site half those wheels are for the old style but your dealer might be able to get them as well
sorry for all the images but sometimes people never get to see what gm has to offer and there backed by your factory warranty.
Nice truck. Gotta love that NBS GMC... I like mine.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
