The Mother Of All Electrical Problems
snsime
I would be amazed if anyone can offer any advice on this... but we're so beside ourselves we're looking everywhere we can to try and glean some help.
Bought a 02 Suburban LT 5.3l not that long ago from a (reputable) used car dealer.
Even when we were test driving it, once in a while I'd hear a clunk from the back of the truck. Discovered a few days after we got it home that it was the rear wiper arm "jumping" in it's cradle. It would do it (intermittently) when we'd lock or unlock doors, step on the brakes, honk the horn, put the truck in gear or put on turn signals. I didn't think it was a huge deal at first.
Then sometimes the wiper started to give a wipe, out of the blue, or when activating any of the above, then go back to it's cradle (jumping still existed). This was begininning to seem pretty strange.
It got to the point where the wiper would start coming on for extended periods of time, particularly when putting it in gear or activating turn signals. It would stop when putting truck in park or turning off turn signals. Now I'm concerned.
Then it went nuts this week. Wiper stays on all the time now when in gear. In park, it won't wipe, BUT, it will turn on when I put either of the turn signals on, step on the brakes, or activate locks. The turn signals have started blinking very rapidly all the time, and will dimly light the opposite side signal as well. Horn has stopped working, but the wiper will wipe when ever "honked" (in park). And the fog lights no longer work either (they certainly did before). I've pulled the wiper fuse from the underhood panel, but the rapid turn signals and all the other problems remain. Strangley, when I was towing our camper trailer this week, with the 7-pin plugged in, the turn signals worked normaly (all other problems remained). As soon as I unhooked the trailer, they stopped working properly again.
This dealer looked at it for two days and couldn't seem to find the problem. It's going back again next week, and they say it will have to go to a specialist.... but they don't seem very optimistic that a bizarre problem like this will be easily corrected.
Sigh. Any insight or advice prior to me spending countless amounts of money I can't afford to spend for someone to try and root through miles of wire - would be most appreciated.
Thanks
With out seeing the vehicle for myself most logical cause would be a bad ground at G203 located at the upper left of the I/P or the body control module.
Thanks very much for the response!
Truck goes in Tuesday Aug 14th, I'll update this thread with progress or (cross fingers) solution.
FIXED! :cheers:
Thanks to the advice here, the techs there checked first for grounds (this feedback was very valuable, particularily because when I told them a GM-Tech has suggested checking grounds, they virtually dismmised it, insisting that that was a parasitic power source or something).
Turns out the ground to the back of the engine block, or one of them, left side I think, was hanging by a thread.
Everything works exactly like it should now.
Thanks again!
-Scott
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
