Helpp! Check Engine Light
Hey, i installed my HIDS today and as i was driving to work i noticed the check engine light pop up, my truck is a 07 1500 NNBS.all stock except hids. i called onstar she said it was something emissions and so on.
would a HID kit trigger a check engine light??Thanks
Chances are it's just coincidental. Could you have accidently disconnected a vacuum line or connection during your installation?
Just for the fun of it, check your gas cap. Did you by any chance recently fill up and not secure it tightly?
It's to bad the trucks don't have the ability to display the specific offending codes on the DIC like Corvettes do...
Hey, thanks for the replys..true it may have been a conicidence that it when on after i installed them.. i had to move my air box lid over when installing them and it may have knocked a hose loose ill have to go take a look..thanks for all the help.
could it be any other problems with the nnbs haveing hids??
Hey, i emailed the company i got my hid kit from and they said theres a "special" wire they sell for 10bucks to bypass the check engine light for th hid kit..not sure anyone heard of this??thanks
Hey -- something very similar happened to me when I put in my HIDs on my 2007 Yukon Denali. Turned out to be a vacuum seal that was undone when I took out the factory intake a few days before, and my new Volant intake had a small hole in the tube after the MAF sensor (which I just epoxied, and it's fine now). DIC indicated "Service Traction Control, Service Stabilitrak, Reduced Engine Power". Check engine light went out after a trip to the dealer (I freaked when all the idiot lights came on). In hindsight, not all that happened at the same time, but the computer has some fuzzy logic whereby if it sees small errors for extended periods of time, it will set a code and the check engine light will come on. Not sure if this helps your case, but don't panic; just check your intake again and make sure the breather hose from the main tube is still connected to the valve cover (if your engine has one of these small hoses), and that there aren't any open vacuum ports on the top of the intake manifold (indicating a missing cap). Once you figure it out, disconnect the negative battery lead for 10-15 minutes to clear the code(s). I know we're talking different vehicles here, but I think your issue may be similar.
Hey, i just called onstar and she told me the code was P0335. Which is a crank shaft position code..so im guessing the hids are not the subject here..haha my truck has 6500 miles on it..not sure what could be causing this??thanks
Hey, just got home from the dealership,turns out the code was "a system glitch"...haha not sure what was going on but they said everything was ok.truck goes back in tuesday for transmission issues and brakes squeeking like crazy.thanks for all the help
    mdh1053
    mdh1053
  • Who's Online   5 Members, 0 Anonymous, 1,324 Guests (See full list)
