matt76 Posted October 12, 2007 Posted October 12, 2007 i have a 98 gmc sierra with 198,000 miles, the check engine light has been on for months. i forget the code number but it basically saying i have an air leake. gas milage is horrible, stumbles when i accelerate. i tuned her up last winter, new fuel pump last winter, my third fuel pump. whats the best way to check for air leaks?
matt76 Posted October 12, 2007 Author Posted October 12, 2007 Air leak in what, EVAP,EGR,Vacuum? sorry, i meant vacum leak and i don't know where it is. is there anything i can do to pinpoint the location?
cmoore74 Posted October 12, 2007 Posted October 12, 2007 We used to use WD-40. Basically with the engine at idle you spray some WD-40 at various locations you might have a vacuum leak. If the engine stumbles when you spray a certain location that's where the vacuum leak is.
Wingnut Posted October 13, 2007 Posted October 13, 2007 We used to use WD-40. Basically with the engine at idle you spray some WD-40 at various locations you might have a vacuum leak. If the engine stumbles when you spray a certain location that's where the vacuum leak is. Might want to use Sea Foam instead...It's good for the internals. WD-40 can dry out gaskets and whatnot. Just my uninformed opinion though
cmoore74 Posted October 13, 2007 Posted October 13, 2007 We used to use WD-40. Basically with the engine at idle you spray some WD-40 at various locations you might have a vacuum leak. If the engine stumbles when you spray a certain location that's where the vacuum leak is. Might want to use Sea Foam instead...It's good for the internals. WD-40 can dry out gaskets and whatnot. Just my uninformed opinion though Good point. Used to use this method before they had sea-foam in a spray can or maybe we just didn't know you could get it in aerosol form.
matt76 Posted October 16, 2007 Author Posted October 16, 2007 thanks for the help, i'll try it out. i'll post a new topic on my findings.
