Where Is The Coil Now?
Do modern engines still have a single coil?
Or has everything been changed and there are multiple coils. Or some computer chip module.
Most modern engines now have individual coils for each cylinder.......basicall sits right above each spark plug.......at least the chevy gas engines do...........not sure about other manufacturers..............so no more distributor cap and rotor.
Good question! I wonder if any manufacturer uses an old technology distributor and single coil system anymore?
The advantage is obvious with coil on plug technology...the likelihood of all 4-5-6-8-10 coils failing at the same time is unlikely.
Another advantage is that each cylinder has the exact same length of wire, and thus would get the same amount of spark.
Also, when changing wires, doesn't matter which wire goes where as they're all the same. ;)
With some kind of crankshaft position sensor and modern electronics everything is much more precise. Engine management software can vary fuel and spark to get the best performance for a given situation. I'm sure this was emissions driven to begin with. Good old EPA... They actually gave us a performance advantage by accident here.
I had a V-6 onces that had a coil for every 2 cyclinders. Each cylinder fired on the compression stroke and between exhaust and intake stroke. IE twice thru the cycle instead of once. Obviously nothing happened the second time but I guess it cleaned the spark plug good and it had 3 coils for the V-6.
If it doesn't have an individual coil for each cylinder, it'll have a "waste spark" type distributor-less ignition. Where a pair of plugs in opposing firing cylinders share a coil. example2.2, 3.1 3.8... gm cars, the new hemi (actually has one coil per plug with a wire running to opposing cylinder also)...
Correct me if I am wrong but I believe the GM 4.3 V6 uses a single coil and a distributer. I know they did a couple years ago.
Don
My '99 Safari did.
