kutu Posted October 19, 2007 Posted October 19, 2007 Does anyone have a good way to remove that tacky sun visor sticker on the new GM trucks?
gmcjoe Posted October 19, 2007 Posted October 19, 2007 When its hot outside ( or use a hair dryer/heat gun carefully!) Grab a corner of the decal and slowly lift it off while holding down the fabric where the decal was just mounted
Zembonez Posted October 19, 2007 Posted October 19, 2007 When its hot outside ( or use a hair dryer/heat gun carefully!) Grab a corner of the decal and slowly lift it off while holding down the fabric where the decal was just mounted Do you know if it leaves a bunch of glue goo behind?
gmcjoe Posted October 19, 2007 Posted October 19, 2007 When its hot outside ( or use a hair dryer/heat gun carefully!) Grab a corner of the decal and slowly lift it off while holding down the fabric where the decal was just mounted Do you know if it leaves a bunch of glue goo behind? No goo
Zembonez Posted October 20, 2007 Posted October 20, 2007 When its hot outside ( or use a hair dryer/heat gun carefully!) Grab a corner of the decal and slowly lift it off while holding down the fabric where the decal was just mounted Do you know if it leaves a bunch of glue goo behind? No goo I'm just gonna have to try that then!
