An3 Seats...
the10thtime
Ok so i have a 06 crew cab silvy and it came with the 40/20/40 cloth half power seat...i bought these avalanche front and rear leather seats and center console and got the interior wiring harness for the truck as well as the drivers and pass. door modules..so i changed everything out...had to swap the cross body harness and had to change the body harness to I/P harness connector as they were diff..but i finally got pin outs for those and put the plug i needed on and now i have full power, heat works in both seats, but the memory only chimes when i hit the buttons...doesnt move the seat...i had a tech 2 on it tonite and was able to verify that i have memory 1,2, and exit inputs on the drivers door module but now what? the class 2 from the door module to the seat has to work because the heat works right? anybody know where to go with this? i was searching SI earlier and found something about it not being able to work unless you had easy entry and exit on in the DIC...but i dont have DIC because i dont have radio controls...??????? any help would be appreciated.
