Harrd Tonneau Cover
My husband has a 2007 chevy silverado 1500 extended cab z71 truck and I want to get him a cover for his truck. We live in Columbus, OH. Where is the best place to get one and how much do they run?
There are lots of different companies out there that make them. (Snugtop, ARE, and Leer are a couple of popular makes). I am sold on ARE covers but they are also a little more on the higher end. Their website at www.4are.com has a dealer locator for your area. Expect to pay between $500 to $1000 for a fiberglass cover.
Other websites:
www.snugtop.com
www.leer.com
You may also consider a hard folding cover, such as advance cover. You can find one for about $ 400 and it is more practical than a solid one piece cover.
How do I know if it is short or long bed?
Actually,Since its a 1/2-ton extended-cab it could be a short-bed,a standard-bed,or a long-bed (They have three bed lengths on the 1/2-ton extended cabs)
PM me the VIN and I can tell you for sure.
Or you could measure it..
5'8"=Short-Bed
6'6"=Standard-Bed
8' =Long-Bed
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
