How Do You Remove 07/08 Headlights
Are you trying to change the bulbs or the headlight housing, If it's just to change the bulbs you have to remove the airbox on the passenger side. On the drivers side remove empty battery tray and the top bolt of washer fluid bottle, that should give you enough room to move it to get to the bulb. If it's the whole housing you'll have to see if someone else can help.
Remove the plastic shroud on top, then unbolt the four bolts that hold the grill on. Take the grill off by squeezing the six clips behind it. Tape off the bumper before you do this. There are two bolts up top and one on the bottom that holds a clip on the headlight in place. You don't have to remove that one but its easier. It can be very difficult to get to though. Once you have the inside edges free, the out side will pull out of the front quarter. Be careful not to twist it around because you can break the side clips off.
Are you clearing the headlights or doing something else?
I need to get them out to wire for a plow. I took the 2 bolts on top and i can see it loose on the bottom but it seems like its stuck by the fender and it wont pull out.
yes there is a hidden bolt down toward the bottom of the light on the outside of the fender,
do try to remove without unbolting that, I did and I had to epoxy the tab back on :D.
once you unbolt the 2 top ones and the bottom one the light sides out side not front.
I too put a light duty plow on and had a time getting to the lighting harnesses below each light.
I did not have to tap a single wire under the hood I had light adapters that go between
the light hardnesses. I have 1 wire that goes to a acessory + and that it.
I hid all my relays down in there for a clean look. I also ran all the wires under that plastic radiator cover.
I was just trying to keep it neat. I installed a second battery just for the plow. its chaging off the 40amp trailer power wire via a circuit breaker
So how do you get to the bolt on the inside of the front fender you are talking about.Thanks for the help.
