07nbs Battery Not Lasting, Maybe Plow Package Upgrade
I listen to my XM all the time, and after 2 hours of radio playing my truck battery goes dead!!
To begin with, I thought these trucks had a 'No go dead' program build into them so I radio will go off before the battery drains beyond the 'I won't start' stage! But mine musn't be working.
Well, my dealer just called me and told me there isn't anything wrong with my truck, and they recommended a trickle charger. Great, sometimes I"m not beside an outlet, so that won't work.
So, now I want to install another battery and wire's like the Plow package.
Is anyone out that has it, does anyone have pics, part numbers and prices.
Thanks
Well my sticker says "Battery Run Down Protection"....so not sure what that actually entails - but sounds like you found a way around it.
I think you have a problem somewhere. I listened to my XM the day I lifted my truck and I was in and out and it took nearly all day and my radio ran probably 6 hours and no problems.
Thanks
I'm not sure this is related, but there is a recall associated with the GMT 900 battery update. I brought mine in a month ago to get the sunroof adjusted (aftermarket) and they told me that they reflashed my 'puter to reflect a recall on the battery. i really dont know much more than that since it was a non issue for me. you might wanna search for this for more details?
The battery run-down protection does not cover the radio,Ive had this happen to me a few times also.
This is from the '07 owners manual.....
Document ID# 1835125
Battery Run-Down Protection
This feature shuts off the dome and reading lamps, if they are left on for more than 10 minutes after the ignition is turned off. The cargo lamp shuts off after 20 minutes. This prevents the battery from running down.
Heres what cm5 was referring to....
Document ID# 1906362
Subject: Service Update for Inventory and Customer Vehicles-Battery Rundown-Expires with Base Warranty #07033B - (02/15/2007)
Models:
2007 Cadillac Escalade, Escalade ESV, Escalade EXT
2007 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007 GMC Sierra, Yukon, Yukon XL
THE SERVICE PROCEDURE IN THIS BULLETIN HAS BEEN REVISED TO ADDRESS VEHICLES WITHOUT A DRIVER INFORMATION CENTER (DIC) AND POWER DOOR LOCKS/WINDOWS, AND A CONDITION WHERE THE ODOMETER READING DISPLAYS METRIC UNITS INSTEAD OF ENGLISH UNITS.
TECHNICIANS MAY EXPERIENCE SLOW PERFORMANCE USING THE TIS2 WEB APPLICATION WHEN REPROGRAMMING THE VEHICLE TO CORRECT THE CONDITION. TECHNICIANS MAY NOTICE THE SLOWER APPLICATION PERFORMANCE FROM MID-MORNING UNTIL LATE AFTERNOON.
TO ASSIST IN IMPROVING PERFORMANCE AND REDUCE PROGRAMMING TIME, IT IS RECOMMENDED TO COMPLETE THE BULLETIN PROCEDURE ON CUSTOMER VEHICLES FIRST. VEHICLES IN INVENTORY SHOULD BE PROGRAMMED DURING OFF PEAK HOURS IF SLOW PERFORMANCE IS EXPERIENCED.
Purpose
This bulletin provides a service procedure to reprogram the body control module (BCM). On these vehicles, and under certain conditions such as operating the radio with the engine off, the battery can become discharged, preventing engine start-up.
This service procedure should be completed as soon as possible on involved vehicles currently in dealer/retailer inventory and customer vehicles that return to the dealer/retailer for any type of service during the New Vehicle Limited Warranty coverage period.
Vehicles Involved
A list of involved vehicles currently in dealer inventory is attached to the Administrative Message (US) or Dealer Communication (Canada) used to release this bulletin. Customer vehicles that return for service, for any reason, and are still covered under the vehicle's base warranty, and are within the VIN breakpoints provided below, should be checked for vehicle eligibility in the appropriate system listed below.
Year
Division
Model
From
Through
2007
Cadillac
Escalade
7R100158
7R350607
2007
Cadillac
Escalade ESV
7R136311
7R350603
2007
Cadillac
Escalade EXT
7G100001
7G274360
2007
Chevrolet
Avalanche
7G100002
7G274351
2007
Chevrolet
Silverado
71500002
71606869
7E500001
7E513617
7F500001
7F500145
7G500016
7G506215
7Z500001
7Z549763
2007
Chevrolet
Suburban
7G100004
7G274344
7J100041
7J318223
7R136280
7R350609
2007
Chevrolet
Tahoe
7J100002
7J318216
7R100001
7R350613
2007
GMC
Sierra
71500001
71606870
7E500003
7E513603
7F500004
7F500140
7G500017
7G506220
7Z500002
7Z549756
2007
GMC
Yukon
7J100040
7J318228
7R100040
7R350611
2007
GMC
Yukon XL
7J108390
7J318203
7R137014
7R350599
Important: Dealers are to confirm vehicle eligibility prior to beginning repairs by using GMVIS. Not all vehicles within the above breakpoints may be involved.
Service Procedure
Important: Technicians may experience slow performance using the TIS2 web application when reprogramming the vehicle to correct the condition. Technicians may notice the slower application performance from mid-morning until late afternoon.
To assist in improving performance and reduce programming time, it is recommended to complete the bulletin procedure on customer vehicles first. Vehicles in inventory should be programmed during off peak hours if slow performance is experienced.
Important: The calibration numbers required for this service procedure are programmed into control modules via a Techline Tech 2® scan tool and the Techline Information System (TIS) terminal with the calibration update. Use TIS 2 Web version 2.0 for 2007 (available on 02/04/07) and on TIS DVD version 2.0/2007 or later, that was mailed to dealers on 02/14/2007. If you cannot access the calibration, call the Techline Customer Support Center and it will be provided.
Notice: Before reprogramming, please check the battery condition to prevent a reprogramming error of any of the modules due to battery discharge. Battery voltage must be between 12 and 16 volts during reprogramming. If the vehicle battery is not fully charged, use jumper cables from an additional battery. Be sure to turn off or disable any system that may put a load on the battery, such as automatic headlamps, daytime running lights, interior lights, heating, ventilation, and air conditioning (HVAC) system, radio, engine cooling fan, etc. A programming failure or control module damage may occur if battery voltage guidelines are not observed.
The ignition switch must be in the proper position. The Tech 2® prompts you to turn ON the ignition, with the engine OFF. DO NOT change the position of the ignition switch during the programming procedure, unless instructed to do so.
Make certain all tool connections are secure, including the following components and circuits:
• The RS-232 communication cable port
• The connection at the data link connector (DLC)
• The voltage supply circuits
DO NOT disturb the tool harnesses while programming. If an interruption occurs during the programming procedure, programming failure or control module damage may occur.
DO NOT turn OFF the ignition if the programming procedure is interrupted or unsuccessful. Ensure that all control module and DLC connections are secure and the TIS terminal operating software is up to date.
Tech 2 Pass-Thru Method for the Body Control Module (BCM)
Verify that there is a battery charge of 12 to 16 volts. The battery must be able to maintain a charge during programming. Use an additional jump battery if necessary.
• If the vehicle will not start, test and charge the battery. Refer to SI for battery testing and charging information, if required.
• If the battery will not hold a charge, replace the battery. Do NOT replace the battery unless it can't be charged or a leak and/or physical damage is present.
Connect the Tech 2 to the vehicle and the TIS terminal.
Turn the ignition to the ON position with the engine OFF.
After all warning chimes inside the vehicle have stopped, turn on the Tech 2.
On the TIS terminal go into SPS Programming.
Select Pass Thru programming.
Follow instruction on the TIS terminal. When you get to the Supported Controllers screen.
7.1. Scroll down in the top box and select BCM (Body Control Module).
7.2. In the lower box select Normal.
7.3. Select Next.
Important: Vehicles without the Driver Information Center (DIC) and power door locks/windows will have two calibrations from which to choose. A selection is requried before you can select NEXT. Select calibration 25814828. Do not select calibration 25788372.
Select NEXT when the calibrations screen displays.
Follow on-screen prompts until programming is completed.
When programming is complete.
10.1. Turn off Tech 2.
10.2. Turn the ignition switch to the OFF position.
Wait 30 seconds.
Turn the ignition switch to the ON position with engine OFF.
Turn on the Tech 2.
Go into diagnostics and check for DTC codes.
Clear all codes.
Important: Failure to successfully reprogram the BCM may result in the odometer displaying mileage in metric units instead of English units. To reset the odometer to display mileage in English units, remove the 10 amp fuse from the underhood BEC. Do not reinstall the fuse for 5 minutes.
Important: After reprogramming the body control module (BCM) the driver information center (DIC) will display tire pressure values as dashes. Do not perform the Tire Pressure Monitor Reset procedure. The Remote Control Door Lock Receiver (RCDLR) will update the instrument cluster with tire pressure values during the next driving event. The vehicle must reach a speed of 40 km/h (25 mph) in order for the RCDLR to update the display.
Claim Information
For vehicles repaired under this service update, use:
Labor Operation
Description
Labor Time
Y0152
Reprogram BCM
0.4
Add: Test & Charge Battery
0.2
Add: Test & Replace Battery
0.4
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Just called dealer and my pickup does not fall under that Document Number.
However, thankyou for your help. I wish you worked at my dealership! But then again, Genie (my lady) seems to do a great job for me!
They are still working on it.
They believe, between the Radio playing and the Brake Controler running, it's putting lots of drain on the battery and killing it!
I don't believe her, however, you never know.
I can believe it,Like I said I've had it happen to me a few times,Once with my '07 and a couple times with the '04 I had.
XM seems like it draws a lot of battery power,The reason I say this is because it seems like I can run the regular radio for hours and never run the battery dead,but on XM it'll go dead within a few hours.
Heck I even drained the battery dead a few times on the '99 that I had that I added XM to.
I installed a second battery in the driverside tray, I put the 40amp fuse in the output for the rear trailer harness power terminal I then connected the battery with a 30amp circuit breaker to the terminal the one toward the outside of the fender on the power dist box.
The reason for the 30amp circuit breaker is if you overload the rear trailer power connector there
would be nothing stopping the wire from frying because the extra battery is using the same terminal.
Also I used 30amp fuse is in the slot for the brake controller power I use that for power to
a 100watt radio transmitter that needed 20amp to run thats the terminal closer to the motor.
so far I have left the radio on for 4 hours
Sounds like adding a second battery would solve our battery rundown issues :thumbs:
I wish GM would offer this as an option on the 1/2-tons again,They use to on the GMT400 trucks because I ordered my '97 with dual batteries.
TopDJ, so,
You've got all the crap like me AND a 100Wt amp and ran your XM for 4 hours and never flattened the battery?
I wonder!
I have 2 batteries now
you cant get the plow pack option on a crew, too many people would put 700lb plows on them and with the weight of a crew cab its too much, my plow is 458Lbs just enough to offest the crews extra weigh.
I ordered a Z71 with the heavy duty towing I have everything in the tow pack but the 160amp alt mine is 145amp, roof light wire and the slotted bumper.
The battery tray was there when I bought it, I think because you can put the extra battery in and run power to your camper.
if I pull the 40amp fuse I can use the spare battery with no effect on the GM installed one
oh I dont have a 100 watt amp I have a 100 watt radio transmitter which was off during the 4 hours I used the factory XM at about 1/2 volume. with 2 batteries it was a no problem
I killed my batt the other night. Doing an oil change and tire rotation with the radio on. Then, tried to reset the darn TPM. An hour and half of frustration later, go to start the truck and see "service vehicle charging system" message! Quick jump and I was back on the road, but just made me even hotter that I couldn't re-program the TPM using the instructions in the manual. The dead battery was just like the truck giving me the finger!
Ohhh, that tire preassure monitoring system is a pain in the ass. However, a great gizmo if you have it!!
My dealer put a new battery in, but I'd be interested to know if thats the only problem. I'm thinking I'm gonna put an extra battery in the cradle. Just got to run a #10 wire to the positive and ground off the negative. This way I can listen to the radio all day long.
