Speed Limit
ove_r
I hav just buy a Silverado form 2007, and found out of that it have a speed limit at 150 km/h.
Is there a possibility to change or remove that ?
Not sure about the 2007, but for earlier models you would have to get it 'turned'. I'm sure the 2007 is no different.
My truck is limited to 170kms, I didn't bother to have the speed limiter removed when I had it tuned since I really don't want to go over 170kms in a 5500lb truck.
However, 150 is a little rediculous. At least if you live in Ontario, they can't pull you over for racing. ;)
And welcome to
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
