Aftermarket Wheels And Tpms Reset
cablecon
I had the stock 20" wheels replaced with 22" wheels with low profile tires to keep outside diameter the same and cannot get the tpms reset. I had horn honk twice and DIC say I was in learn mode. Went to LF and let air out for 30 sec. No horn honk, but kept letting air out then after 2 min it goes out of learn mode. Any suggestions? Thanks in advance
I followed this procedure
1. Take all four valvestem caps off.
2. Find a tool such as a small diameter philips screwdriver that will work to let air out of the valvestem. A common aluminum 1/8" rivet (round end into valve stem) works very well.
2. Add air so that the tire pressures are all 40+ psi (do not exceed the tire's max. inflation rating on the sidewall).
3. Turn key to on position.
4. Apply parking brake.
5. Press and hold lock/unlock down at the same time (for about 3 seconds) on the key fob until the pickup honks.
6. Start at the LF tire.
7. Let air out for 4 seconds - count it out (one one-thousand, two one-thousand, three one-thousand, four one-thousand).
8. Wait for about 15 seconds* for the honk (sometimes it'll honk right away).
9. Repeat 7 and 8 for the RF tire.
10. Repeat 7 and 8 for the RR tire.
11. Repeat 7 and 8 for the LR tire.
12. With all four now done, the system will give it's final multi-honk completion note.
13. Use a quality gauge to set your final pressures (a good gauge will exactly match the sensor readings).
14. Replace all four valvestem caps.
*If you've waited fifteen seconds for the honk and nothing has happened. Don't panic - Simply repeat 7 and 8 again as there is a two minute window to do each tire sensor.
I rotated the tires on my truck about 2 weeks ago and could not get the relearn to work, called the dealer they said bring it by that they had a tool they just touched to the side of each tire and it relearned the postion. Its agravating when you go through what the book says to do and it doesnt work.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
