Plow Question
I have a 2001, gmc, sierra, 5.7, ext cab, Z71...
I am looking for a used plow setup. I dont care if its a boss, fischer, myers, etc.....My truck has the tow package with the tranny cooler.....
My question is, I see all these used plow on craigs list and the local "want ads". Can I adapt most of these plows for my truck as long as I can buy or find the correct push plates?.... I've been told to stay away from the pulley over hydralic operated plows, and go with an electric over hydrolic..... Any suggestions, and yes, as always im on a budget...
Thanks
Mike
Mike............You won't have any problem mounting a plow to your truck.
As far as choice a Western or Fisher straight blade no larger than 8 ft.
would be my choice. Used/new parts are reasonable and easy to find.
These are also simple units...........................
Just use caution when buying and look for a used unit came off the same or
similar year truck.
Parts are pricey ! A new push bar (mounting carton) is $500. Wiring
harnesses are $250 a pop and your gonna need 2 !!!!!!!!!!!!!!!
So that cheap plow that came off a Ford or mopar is gonna cost ya $1000
bucks in parts to make it work on your GM !
If you find a used plow unit check the "plow match" feature on their
web sites to see if the wiring harnesses and mount will work on your
truck. Good luck...............geo
Check out http://www.letstalksnow.com/forums for more help/info.
he's got a good point a used one can cost a lot once you add up the extra parts
Thats why I bought a new plow " light duty" you may want a standard duty plow
as the light duty ones dont have the weight for anything other than personal use.
Im already considering trading my plow in for a regular duty version of the same brand
it won't require anything but droping off one and driving away with another,other than more $$
check out www.PLOWSITE.com too
