Service 4wd
dudg
When running my 2005 Suburban K2500 in Auto 4WD the warning "SERVICE 4WD" will come up in the DIC. I am unable to switch back to 2WD unless I turn off the ignition and start it again. Any ideas?
Thanks
It could be the sensor in the transfer case or the motor itself (in the transfer case). Since it is showing "Service 4WD", it is probably the sensor. It wasn't too hard to replace, but I had to drop the front shaft on my 2005 GMC Sierra 1500 Quad Cab.
you can thank me later :lol:
999999995.gifSubject:Service 4WD Light Illuminated, DTC C0374 Set (Inspect Wiring Harness to Transfer Case Speed Sensors, Replace Wiring Harness) #05-04-21-003B - (08/20/2007)
Models:2004-2007 Buick Rainier
2003-2007 Chevrolet Avalanche, Silverado Classic, Suburban, Tahoe, TrailBlazer, TrailBlazer EXT
2003-2007 GMC Envoy, Envoy XL, Sierra Classic, Yukon, Yukon XL
2003-2004 Oldsmobile Bravada
2005-2007 Saab 9-7X
with Four Wheel Drive or All-Wheel Drive
and Active All-Wheel Drive (RPO NP4) or Active Two-Speed (RPO NP8) Transfer Case
This bulletin is being revised to add the 2007 model year, remove the Escalade model and update information in the Correction section and Parts Information. Please discard Corporate Bulletin Number 05-04-21-003A (Section 04 -- Driveline/Axle).
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=2004248&psdid=1038&evc=sm#ss1-2004248">
Condition
Some customers may comment on intermittent illumination of the Service 4WD light. Upon investigation, the technician may find DTC C0374 set. The customer may also comment on intermittent erratic operation of the 4WD or AWD system after driving through rain/snow or simply going through a car wash.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=2004248&psdid=1038&evc=sm#ss2-2004248">
Cause
The speed sensor signal may have become corrupted. Possible openings in the speed sensor wire insulation (twisted pairs) can allow water intrusion. Also, wire connections contaminated by water may result in short circuits and erroneous speed sensor readings. This most often occurs on the rear speed sensor circuit.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=2004248&psdid=1038&evc=sm#ss3-2004248">
Correction
Inspect the wiring harness to the transfer case speed sensors. On Rainier, TrailBlazer, Envoy and 9-7X models, fabricate a replacement speed sensor harness between the C101 connector and the speed sensors. Completely inspect and test all wiring . Refer to Speed Signal, Front Axle Actuator, and Indicators schematic in SI.
Replace the affected twisted pairs. Do not over-twist the two wires in the replacement harness. Wires should be twisted at a rate of 9 revolutions per foot . Use service connector pack, P/N 88987993, at the speed sensor end and terminal, P/N 15326267, at C101.
Terminal testing tools and service terminals can be found in Terminal Repair Kit J 38125. Terminals are available from SPX/Kent-Moore. Call 1-800-GM-TOOLS (1-800-468-6657).
The smaller transfer case harness splices into the larger chassis harness a few inches in front of the crossmember. The chassis harness routes along the left side of the frame under the driver door area. Use nylon tie straps to secure the fabricated harness to the main chassis harness between the transfer case and C101.
On the full-size pickup and full-size utility models, replace the 2.2 m (88 in) pigtail harness that runs from the C151 connector under the hood to the transfer case. Use either harness, P/N 15224661 or 15224663, depending on vehicle equipment. Refer to Propshaft Speed Sensors, Front Axle Actuator and Transfer Case Shift Control Switch schematic in SI.
Important: Technicians should verify the integrity of the splice joints after the repair. All splice joints and connections should seal properly against water or a repeat condition can occur.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=2004248&psdid=1038&evc=sm#ss4-2004248">
Parts Information
Part Number
Description
15832722
Harness Asm-Transfer Case Sel
(4WD Full-Size Pickup/Utility w/NP8 and without Four Wheel Steering (NYS)
15224663
(4WD Full-Size Pickup/Utility w/NP8 and Four Wheel Steering (NYS)
88987993
Connector-w/leads, 2-way, Female (Speed Sensor)
(All Vehicles)
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=2004248&psdid=1038&evc=sm#ss5-2004248">
Warranty Information (excluding Saab U.S. Models)
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
N6630
Wiring And/Or Connector-Transmission/Transfer Case/Transaxle/Front and Rear Axle Control - Repair or Replace
Use published labor operation time
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=2004248&psdid=1038&evc=sm#ss6-2004248">
Warranty Information (Saab U.S. Models)
Labor Operation
Description
Failed Object
Fault/Reason
Location Code
Warranty Type
Repair/Action Code
Labor Time
3714901
37149
67
01
Use Published Labor Operation Time
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
999999994.gifWE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Document ID# 2004248
2005 Chevrolet Chevy Suburban
Thanks for the great info!
Rodger ,you are giving out missinformation,do not asume he has this code,and fire this bulletin,this guy needs to take it to a dealer,simple,scan it ,simple,fix it,I have done a thousand encoder sensors & reprogram for a 327 code ,it is possible he has that to ,stop being a hero,give possibilites not for sures,get it.
I don't mean to be a jackass, but is there a chance that the 4wd need serviced??? TC fluid level good? Just putting it out there. :thumbs:
I don't mean to be a jackass, but is there a chance that the 4wd need serviced??? TC fluid level good? Just putting it out there. :fume:
your not a jackass ,the message does not mean to get the oil chg'd,it means there is a code in the TCCM and instead of an SES light ,they put in a message
Hey big guy, calm down. All he did was post some great info on a COMMON problem and how GM stealerships are supposed to check it out. Maybe the OP is like me and prefers to fix it himself. So GMtrucktech was posting an official GM bulletin related to the question dudg asked. How is that "missinformation"? Perhaps you might stop being such an anti-hero, and realize that most people on here post information that they feel may be useful. Most people realize that the info on this (or any website) is just FYI, and each individual case may be different. Get it?
Dudg, another possibility is the actual switch in the dash has gone bad. Do a search for "bad 4WD switch" and see what pops up.
thx for your input,I am a gm tech,he still needs to have it scanned ,rodgers bulletin was for a code ,there is several bulletins for TCCM codes ,do you get it?
JUST TRYING TO HELP A FELLOW TRUCK GUY. Not a newbie gmtech4 been working on gm trucks since the tender age of 12 and been at the dealer for 10 years holding down the truck department so relax and drink a beer bro. Your right it could anything but trying to give as much info as possible. Later
we both care ,that is obvious ,take care rodger,enjoy the warm winter,you )(*&^%%$$,lol,cya-Rob-
  • 1 month later...
Turns out the tech found a code C0374. Tested a bad Encoder motor. And replaced the Actuator.
Thanks for all your help
I think i'd be thankful I didn't throw a speed sensor and spend a couple of hours twisting a pair and repining connectors without a code to go by.
It's misinformation if all you have to go by is a vague description of a problem and you give a bulliten as a fix saying you can thank me later, as if this could be the only fix, I've had at least a couple hundred service 4WD messages and never used that bulliten as a fix.
I'm not trying to beat up anybody or side with anyone but this is a new fix to an old post. We could have saved some time and probably some money if we found out a code without shooting off a bulliten. There are probably a hundred Service 4WD bullitens.
Alot do, not most. When you go to the Ask the GM tech link my guess is most think your getting qualified answers not a guess.
    • I had a little bit of time before I left for work this morning, so I plugged the scanner back in, and I selected Chevrolet Silverado instead of GMC Sierra, and the very first option was for a 2026 so I selected that one and I seen at the bottom it had the option for psi change unlike in the 2026 GMC Sierra, I selected that option and it took a little longer than the usual vehicle not supported, and sure enough I got into it, and it let my change the psi values.. I no longer have the low psi warning light!   Thank you for recommending me to try it under Chevrolet instead! I can confirm this device does work for a 2026 GMC Sierra 2500 hd 6.6 diesel  just have to select Chevrolet Silverado instead of GMC Sierra.   Maybe I'll contact Autel and let them know of that issue and maybe they will fix it for the GMC option  because some people probably return the scanner due to it not working under GMC Sierra.
    • I just did a little bit more research, and it seems that this Avalanche is not a Global-A vehicle, because the charts seem to list several models that were Global-A starting in 2010, but the Avalanche is not on there. And even similar models such as the Silverado are not on the Global -A platform until later in 2013. Please correct me if I'm wrong.
    • Yes, the 2007 is a GMT 900. Originally I had ruled out computers/compatibility as a problem because I did not change over any computers, only the engine. I know that the motors are different codes, but it seems like the lmg to lc9 is a fairly common swap, at least from what I can read online. I'm using all the wiring and sensors from the 2010 vehicle, as well as the computers (the only exception to that being the MAP sensor).
    • Real Truck handles the warranty via GM.  We don't submit a warranty claim with GM, we have to submit it with Real Truck with a specific email/phone number.  Real Truck determines if the issue is covered or not based on the issue and pictures submitted.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
