Starting Problem
I have a 2003 K3500 Silverado with the Duramax/Allison combo. Lately when I have started the engine in the morning, I get a clickiing noise coming from the engine department, sometimes this happens a couple of times as I turn the key then the engine starts up; but the clock has reset to 12:00. Does anyone have an idea what is causing this?
Disconnect your battery terminals and make sure the connections are clean of dirt and corrosion, maybe check the connection to the starter.
