Any Body Doing Home Fuel Filter Changes Here?
http://www.gm-trucks.com/forums/index.php?showtopic=72100
If you have a newer 5.3, chances are you need this disconnect tool, I bought it thinking I needed it for mine, but dont. Its brand new.
On a side note, I changed my filter today, it wasnt "that" dirty, but it looked like it went through h**l and back, as far as rust on the outside, so I changed it anyways. Easy, just a 16MM wrench 13MM wrench, and a adjustable did the job in under 15 minutes
I was told that my truck does not have a fuel filter, only a strainer in the fuel tank. :thumbs:
Hmm... look inside your driver-side frame rail between where the bed starts and the rear tire.
I know my 2000 Sierra does. Since it was changed, my fuel pump hasnt been whining near as loud.
I was told that my truck does not have a fuel filter, only a strainer in the fuel tank. :fume:
First post here! I believe years 2004 and newer have a fuel filter system that is not serviceable. I just changed mine (2002 sierra) last week. It was an easy job. I just bought the truck and I don't think that it was ever replaced. There was all sorts of junk in it, and it wasn't easy blowing through the old filter... I removed the fuse for the fuel pump and started the truck until it stalled... that way the fuel didn't spray when I removed the old filter. :rollin: I got that tip from my bro in law... just don't forget to put it back in when you're done!
Pete There is a filter and a strainer both in the tank on your truck.
is there a change in performance when you change the filter or just more efficient ?? ??
Brian It depends on the condition of the filter. Changing a moderatly plugged filter will make it more efficent. I have found badly plugged filters will cause people to come in with all kinds of problems. No starts, check engine lights, poor fuel economy, failed emissions and even transmission shifting concerns. Every station has different impurities in their gas. I recommend customers change the changable ones every 30k or so.
    250.3k
    RobbertClaus
    RobbertClaus
  • Who's Online   5 Members, 0 Anonymous, 517 Guests (See full list)
    • No I didn’t watch a video of a person who analyzes oil for a living explain general oil usage. For clarity I did ask my brothers one who runs our equipment business. The other who runs our old ROW business about oil usage. Nothing has changed since I retired. Their personal vehicles or work vehicles use no oil. Not enough to see on the oil checking device. Then I pondered. I like to ponder. In this extended oil changing world with oil change countdowns or lights. If engines used say a qt every 2500 miles or up to even 4000 miles. With oil changes reaching as high as 15000 miles. Normal for most people is eight to ten. Vehicles should potentially be seizing up all over the place. Especially in hilly terrain. Just how many people actually check their oil? Maybe 10 percent. Those are the people that probably change their oil early. I like to research used car listings. I have five favorite dealers I check. They all list carfax with their listing. It’s rare to see vehicles with anything but extended oil changes. Transmission service, forget about it. I’ve seen Honda and Toyota certified vehicles up to 100K miles and ten years old. With nothing but normal maintenance. Isn’t nice we all have different experiences and believe our way is the best. You certainly get backup for whatever you believe. Life would be boring otherwise.
    • Interesting rumor. Dealers near me have been tight-lipped so far, but if this reveal actually happens next week, I'm really hoping they finally give the HD a proper interior overhaul. The competition has been eating their lunch in the cabin department for a while now.
    • There are a few good takeaways in that video that pertain to this thread, certainly the possibility of the oil control rings having buildup, the fuel injectors and how clean or not that they are ending up affecting the pistons rings carbon buildup, and the fact that its normal up to a point for a given engine to use some oil, and that the oil quality that is being utilized is part of that ring clogging up issue as well.   I was talking with a neighbor yesterday who has a baby LZ0 duramax and he had bought it slightly used but it does consume some oil and he has switched over to 5W-30 Euro spec oil and in this case that never made a difference in consumption over the factory 0W-20 recommendation. He finds it uses a quart in about 3500 miles and as he goes a ways over that distance he adds oil to full and goes another 1000 miles or so and then changes oil and is typically at 40% or so left on the oil monitor at that point with his use case of quite a lot of highway miles and more limited in short run use. I don't know what other LZ0 engines are doing for oil consumption but that is what his is doing.
    • I dont care what Lake says. Goodnight.
    • Ok well I guess Lake disagrees with me on a few points. I call oil consumption pretty basic. Rudimentary. He calls it "really complicated." I think 1qt consumed in 3k miles is a lot. He says that's normal. In 22 minutes, he'll use his natural talent to explain oil consumption to anyone watching this video. He covers everything from obvious engine damage to how normally functioning healthy engines consume oil by design. Lake explicitly states how you drive will impact oil consumption.   Shut up and watch:
