Rattle Is Driving Me $#$$@! Crazy
hi all.
i have a 2006 silverado 1500 ext cab, 19k miles. recently a very annoying rattle has developed and seems to be coming somewhere from underneath or behind the driver dash. it does not occur on very smooth streets or > 50 or so MPH.
i have removed as much of the dash as i know how including the instrument panel, but could not find where it is coming from.
i have read all about the steering/intermediate steering shaft problem (with the greasing of the u joints), however it seems like people describe more of a "clunk" sound rather than a rattle; although at times i do also feel the clunk as well.
interestingly, when the rattle is occuring, ive found that if i give the steering wheel a solid whack it will quit for a short period of time.
has anyone had something similar to this, or can anyone offer any kind of insight on what it is/how to get rid of it? this rattle is totally driving me crazy, especially since i cannot find the source.
i am so desperate about this that i will feel obligated to give a reward to anyone who can help! :)
thanks in advance.
may not help. but i had the same problem and could never figure what the noise was until the bolt feel out of my over head console.. screwed it back in and no more rattle.. just a thought...
As the steering/intermediate shaft problem gets older/worse it's a more rapid clunk almost a rattle. Especially when turning, but nothing on flat roads. Just what happened on mine.
I hope you find the problem before you shoot your dash. :)
1990 Chevrolet 1500 Regular Cab 2WD Long Bed.
I recently replaced the instrument cluster lens. I bought a new one years ago from dealer with intentions of replacing the slightly scratched one when selling truck. I finally did this. And I found some change back there - coins. This model cluster has something like a small shelf and I used to put all sorts of stuff there. Well, coins slipped under.
You got any kids? Good friend passengers? Pranksters?
Anything could be back there. Something could have fallen into the defrost vents - heater. Coins, pens, you name it.
I was driving with some friends child and as I was driving I watched the kid actually try to push a pen into the heater vents. And I was there. What happens when you are not there?
$0.02
Is the rattle something you can feel through the steering wheel?
not at all. i do feel the clunk when it happens though.
where abouts is this bolt?
i was wondering that. i thought about having the dealer replace the shaft to cure the clunk problem and was wondering if it would fix the rattle in the process.
i was wondering if something like this had happened which is why i pulled the dash apart. i may go back today and remove again including top part to see if i can see anything.
thanks to all, if anyone else has input i would love to hear it.
My brake wiggles in my '05, its like a fast rattle sound, not loud but you can hear it, stops when you use the brake ofcoarse. Could be the same in your case, On a straight lumpy road keep monitoring your brake pedal see if it wiggles left to right. As for a fix, I dont know mines bolted up solid but still wiggles, my exhaust kills the sound of it though so its not much of a big deal anymore.
I had some rattling a while back myself, and it took some second eyes, but mine was coming from under the dash. It was a piece of metal rattling. Upon the second look, there were a few vertical metal brackets under the dash that were missing some bolts. I taped it, but this reminds me, I'd like to take care of it for good, and put some bolts back on the brackets. They look like dash brakets, and are above the pedals, under the steering column. I'm not sure if this is your issue, but it couldn't hurt to look under there with a flashlight, just to check.
just an update.
took the truck into the dealer for this. had it back to me in just a couple of hours; said it was a lower bearing in the steering column.
im feelin good about it but i wont know for sure until the morning; it does not rattle once the cab has heated up.
    Greg3160
    Greg3160
  • Who's Online   5 Members, 0 Anonymous, 501 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
