Heated Drivers Seat Issue
A good friend of mine has a 2003 GMC 1500 SLT.
The drivers heated seat comes on and changes settings at will. This problem only happens when it is damp or wet out. If it rains overnight but is dry in the morning, after about 5 miles down the road, it will eventually turn itself off and work properly. If it is rainy, snowy or foggy, the drivers heated seat will come on, off, and change settings constantly. When it is dry outside, the seat functions properly.
The truck has been to two different dealers with no real suggestions other than to start replacing parts to see which one may have failed. Each dealer sprayed the outside of the drivers door as well as under the hood towards the wiring harnesses and the problem never happens for them. The fuse has been pulled and the seat still acts the same. They have plugged the truck in and there are no codes showing either.
Anyone have this problem and have any solutions or does the truck have a ghost??
Thanks!
Mine does this in the same situations you mentioned. I do not know a fix for it, but the next time I get an oil change then I will ask them to take a look at it. My horn also does not work sometimes also. If I find out anything from the dealer I will let you know.
Here is some info that 'may' help:
Document ID# 1469580
2003 GMC Truck GMC C Sierra - 2WD
Subject: Driver or Passenger Heated Seats Turn On By Themselves - kw GMT800 GMT805 GMT820 GMT830 seat unwanted heat right left front switch operation #PI01850 - (03/08/2004)
Models: .
When servicing the vehicle with the VIN you entered, the following diagnosis might be helpful if the vehicle exhibits the described symptoms.
Condition/Concern:
A customer may comment that the front passenger or drivers heated seats turn on by themselves. Dealer technicians my not be able to duplicate the concern and no DTCs will be set. This concern maybe caused by the customer inadvertently contacting the heated seat switch.
Recommendation/Instructions:
To correct this concern, a new low profile switch has been released. The new part number switches are as follows:
15116861 passenger
15116862 drivers w/ memory, heated, and adjusted pedals
15116863 drivers w/ memory and heated only
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance. This diagnostic approach was developed for the vehicle with the VIN you entered and should not be automatically be used for other vehicles with similar symptoms.
Models:
(03 and 04 Chevrolet Silverado) and (03 and 04 Chevrolet Avalanche) and (03 and 04 Chevrolet Tahoe, Suburban) and (03 and 04 GMC Sierra, Sierra Denali) and (03 and 04 GMC Yukon, Yukon XL, Denali, Denali XL) and (03 and 04 Cadillac Escalade, EXT, ESV)
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
and possibly switch closing circuit when moisture is in air?
  • 1 year later...
The same thing happened to me today. Here in Eastern NC we had major storms come through last night, with the wind and rain blowing at the drivers side of the truck. Today when I left the house, the seat heater on the drivers side started coming on by itself, cycling through all settings. I would punch the buttons to turn it off, but 5 or 10 seconds later it would come on again. The truck was parked in the bright sun during lunch, and on the way home it never did it again. Gotta be a moisture issue. I just wonder if the new style switch will fix it? :P
Let me know if your dealer replaces your switches and that fixes the problem. Mine has been doing it for awhile now off and on and my dealership has no idea.
The same thing happened to me today. Here in Eastern NC we had major storms come through last night, with the wind and rain blowing at the drivers side of the truck. Today when I left the house, the seat heater on the drivers side started coming on by itself, cycling through all settings. I would punch the buttons to turn it off, but 5 or 10 seconds later it would come on again. The truck was parked in the bright sun during lunch, and on the way home it never did it again. Gotta be a moisture issue. I just wonder if the new style switch will fix it? :uhoh:
  • 1 year later...
Models: .
Condition/Concern:
15116861 passenger
Models:
Thanks, Mike. I wonder if the switch that was developed for the 2004 problem is the same switch that comes standard in the 2006 model Silverado, or do I need to have the dealer order this "new" switch???
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
