wipers work every where but on delay. low speed, high speed, washer works,4 swipes then stops, rear wiper works fine also. every thing but the delay. already replaced the pulse board(twice),so thats not it, any ideas?
Wish I could help you, mine just started doing the same thing. It is either unpredictable (long delay, two quick sweeps, short delay, one sweep, etc.) or works like it's just on Low. When I turn the wipers off, it will finish the sweep and then make another. Same when using Mist, it will make two sweeps instead of one. Pulse board had already been replaced, I pulled it out and inspected it, cleaned the contacts, and put it back in. Wiper worked fine for about a week before they started acting up again.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
