Start Up Honking Noise
I own a 2004 Sierra 4.8L and I've noticed for about a month now that I get a quick honking noise at start up. This only happens once a day when the temp is cold outside. Also, If I shut the engine off immedietly and start it up again, the honking noise will not be there. Anyone else have this problem? It really annoying.
a buddy of mine had a CAT that was sitting on his tranny. he would just sit there and when he got out he would hear a meow or two. i twas there for about a week before he chased it out. it was a 98 Silverado
it could be coming from your power steering pump. when the fluid in there is really cold it doesnt like to move therefor makeing a noise simmelar to what you are explaining
I have the exact same problem. Only happens when cold and the first start. There's also a TSB on this about having an out of position power steering pump mounting bracket. The issue is called a "cold start squawk". I have a copy of the TSB and can PM it to you if you like.
I took it to the dealer as it's under warranty, but they "could not reproduce the problem" as it only happens first thing in the AM and it has to be cold.
To get it fixed you may have to leave it over night and make sure it's gonna be cold enough the next morning. I have not yet left it there over-night to get it fixed.
Could you please post the TBS?
Thanks,
Mike
Yes that would be great. I have a PCM tune and I want to make the mechanic aware of this before something gets worked on (no warranty also). Wait......will this effect a custom PCM tune if it's a computer problem?
Thanks, I was begining to think I was the only one with this problem. :D
i've got that same noise on cold starts....the work truck i used to have (2007 F350 SD) did is as well, only 100 times worse. I just kinda figured it was normal as it only does it for a second.
Here ya go, it's a long one...
Subject:Accessory Drive Belt Chirp, Squeal or Squeak Type Noise at Cold Idle (Replace A/C Compressor/Power Steering Pump Mounting Bracket or Enlarge Bracket Bolt Holes) #05-06-01-018A - (03/07/2007)
Models:2004-2007 Chevrolet Silverado (Classic)
2006-2007 Chevrolet Express
2004-2007 GMC Sierra (Classic)
2006-2007 GMC Savana
with 6.6L Duramax® Diesel Engine (VINs D, 2 - RPOs LBZ, LLY)
This bulletin is being revised to add additional model years, models and update the technical content. Please discard Corporate Bulletin Number 05-06-01-018 (Section 06 -- Engine/Propulsion System).
Condition
Important: It should be noted that a chirp type noise on engine shutdown is normal for a diesel engine due to higher engine compression and the rapid stopping of the crankshaft. No repairs should be attempted for this condition.
Some customers may comment on an accessory drive belt chirp, squeal, or squeak type noise at idle, especially on a cold start. The noise may be reduced or go away after the engine warms up.
Cause
Some 2004/2005 Silverado or Sierra trucks, with a 6.6L LLY engine produced before June, 2004, may have an A/C compressor/power steering pump mounting bracket and power steering rear mounting bracket that are machined slightly out of specification, causing a misaligned power steering pump.
If the power steering pump is misaligned, it will force the accessory drive belt to run farther inboard on the fan pulley. When the belt leaves the fan pulley, the belt will not align properly to the crankshaft pulley grooves and create a chirp or squeak type noise at the point of interference.
Vehicles built after June 2004 will already have the new A/C compressor/power steering pump mounting bracket installed, but still may exhibit belt noise caused by the power steering pump rear mounting bracket.
Correction
Vehicles built prior to June 2004, replace the A/C compressor/power steering pump mounting bracket.
Vehicles built after June 2004, enlarge the rear power steering pump bracket bolt holes.
1. Follow the published service information (SI) diagnostics for drive belt chirping. The diagnostic chart for the drive belt chirping will ask to inspect for a misaligned accessory drive pulley.Important: Remove the top section of the radiator shroud and TCM/cover to gain access to check alignment and measure the power steering pulley on the power steering pump shaft.
2. Verify that the power steering pulley is properly pressed onto the power steering pump shaft. Refer to SI for the power steering pulley replacement. If the pulley needs to be realigned on the power steering pump shaft, follow the published SI procedures for the power steering pulley replacement.
3. If the noise was not fully eliminated by the procedure in step 2, the power steering pulley may be adjusted with an allowable maximum variance of 1.0 mm (0.039 in) to the front from the flush position on the shaft to assist in eliminating any remaining belt noise. Refer to graphic illustration number 1 and number 2. Ensure that the power steering pump pulley illustration number 1 is flush against the power steering pump shaft illustration number 2, with an allowable variance of 1.0 mm (0.039 in).
4. If the noise was not fully eliminated by the procedure in step 3, and there are no other concerns found, follow the published SI diagnostics for drive belt chirping. Then, if the vehicle was built prior to June 2004 go to step 5. If the vehicle was built after June 2004, go to step 6.
5. Vehicles Built Prior to June 2004:
5.1. Replace the A/C compressor/power steering pump mounting bracket with P/N 97362175. Refer to graphic illustration number 1. Follow the published SI procedures for the Air Conditioning (A/C) Compressor and Power Steering Pump Mounting Bracket Replacement.
5.2. With the new A/C compressor/power steering pump mounting bracket installed, reposition the power steering pump to gain access to drill larger holes into the rear mounting bracket using a 14 mm (1/2") drill bit. Drilling the bolt holes larger will ensure proper alignment of the bracket when installing the bolts. Refer to graphic illustration number 2.
5.3. Install the power steering pump to the A/C compressor/power steering pump bracket. Refer to graphic illustration numbers 4, 2, and 1.
Important: Power steering pump front mounting bolts must always be tightened first to ensure correct pulley alignment.
5.4. Refer to graphic illustration number 4 and tighten the front power steering pump mounting bolts.Tighten
Tighten the bolts to 50 N·m (37 lb ft).
5.5. Refer to graphic illustration number 2 and tighten the rear power steering bracket bolts.Tighten
6. Vehicles Built After June 2004:
6.1. Remove the front and rear power steering bracket bolts from the A/C compressor/power steering pump bracket. Refer to graphic illustration numbers 4, 2, and 1.
6.2. Reposition the power steering pump to gain access to drill larger holes into the rear mounting bracket using a 14 mm (1/2 in) drill bit. Drilling the bolt holes larger will ensure proper alignment of the bracket when installing the bolts. Refer to graphic illustration number 2.
6.3. Install the power steering pump to A/C compressor/power steering pump bracket. Refer to graphic illustration numbers 4, 2, and 1.
6.4. Refer to graphic illustration number 4 and tighten the front power steering pump mounting bolts.Tighten
6.5. Refer to graphic illustration number 2 and tighten the rear bracket bolts.Tighten
Dual Generator System
New belts are not available for dual generator systems. If a belt chirp noise is occurring on a dual generator system, please complete a Field Product Report (FPR). The instructions for completing a FPR can be found in Service Bulletin Number 02-00-89-002F.
Parts Information
Part Number
Description
Qty
97386417
Bracket, A/C Compressor and Power Steering Pump Mounting
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J7509*
A/C Compressor and Power Steering Pump Mounting Bracket - Replace
(Vehicles Built Prior to June, 2004)
0.7 hr
Add:
Enlarge Rear Power Steering Pump Bracket Bolt Holes
(Vehicles Built After June, 2004)
0.3 hr
Add:
Removal of Auxiliary Generator (if equipped)
0.1 hr
*This is a unique labor operation number for bulletin use only. This number will not be published in the Labor Time Guide.
It also could be the fluid as well as someone stated previously. I read where a switch to valvoline synthetic power steering fluid could help if the problem described in the TSB is not the culprit.
    250.3k
  • Who's Online   3 Members, 0 Anonymous, 1,500 Guests (See full list)
    • Without knowing how bad your banging is, one suggestion is the intermediate steering shaft on the steering wheel. These used to be a problem on 800 and earlier series. The feeling/sound was sometimes described as "clunking" and was felt in the wheel. Also there is a plastic piece in the lower column that is referred to as a bearing. Not your traditional looking bearing though. Your ball joints, bushings and tie rods or steering rack (if equipped) are the main point of issues. You never mention total unit miles, only that you've put 60k on it.   You can search the site for help on the ISS description. Plenty of these have been replaced   https://duckduckgo.com/?t=ffab&q=site%3Agm-trucks.com+intermediate+steering+shaft&ia=web
    • Yes I have is set with the 1mm disk (Minumim Tension), for spring spacing and I raised my truck in the rear 1.5". You can go 2mm  and I think 3mm if you need.Minimum. We are on our way to TN from GA.. My wife is driving and stated she cannot believe  and   stated she can not belive the difference.
    • Most 1 ton trucks come with the factory overload spring, which need to be removed for installation of RoadActive Suspension. Removing the overload allows proper fitment and ensures the system works as intended. The RAS® Mega-Duty kit will reduce squat and provide significant improvement vs the factory overload spring.
    • I wonder as well, why they would send me a text message with links to these suggested procedures totalling over $10,000 without even the slightest hint of how they arrived at these being necessary.
    • https://precisionlubrication.com/articles/oil-filter-efficiency/     For them it is a problem of $$$$ and compliance. To cover both they have to lie from the heart.    Government wants low waste oil numbers so the bar needs to be very low on contamination to met that requirement.  Consumer wants cheap maintenance (perceived cost). Again requiring a low bar.  OEM wants high margins at a cost effective warranty rate and lots of repeat customers. More low bar.  Filter manufacture wants the same thing the OEM wants. See the pattern?   Consumers are fickle and also want perfection requiring a HIGH bar. Inconsistent with all of the above. Consumers can be, when the put their minds to it, inquisitive, love winning arguments which requires some useful information to be available to support them. And this is where it gets sticky and the lies begin.    Information needs a solid well grounded point of reference if we are to compare in a useful way. There is a standard for this.  ISO 4548-12. This standard sets the particle size at a specific Beta ratio and darn few are faithful to its intent.    If they don't state the test method they change the particle size or the Beta ratio to hit a perceived favorable standard. They obscure the information in a way as to prevent direct comparisons leaving the consumer with one method. UOA's with an ISO 4406 test result. Pricey and not allot of labs willing to do the work. Lobby work happens everywhere, not just at the seat of government.
