2004 Chevy Truck Armest Removal
superjeep
It's held in by a clip that is simiar to the clip that holds on a manual window crank. You need to roll the seat cover up to access the clip. Good luck this job is a pain.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
