Front Leveling Kit
It kinds of depends on where you want to install it. If your doing the install yourself I think that roughcountry is the fastast, and probably cheapest one out there. Good results too, althought my truck is not perfectly level, its way better than it was. I'd vote roughcountry for the price and ease of installation.
ok thanks
i was looking at the rough country kit
earlier
do i just but the spacers or do i need the torshon bars things
+1 for the rough country.. I love it... You never want your truck perfectly level unless your not going to haul heavy loads. Your headlights will be pointed at the moon like the bat signal.
ok thanks
earlier
07-08 GMT- 900's don't have torsion bars....its a strut type set up now. Just spacers. The rough country spacers go below your shock. Quite a nice setup.
ok thanks
earlier
yeah i think i found it its basically a black spacer that raises the piont where your strut assembbely bolts on too
can it be put on with a floor jack in the drive way?
ok thanks
earlier
Yea it sure can, just make sure its on a couple jackstands and your good to go.
disconnect the stab bar and the upper ball joints ( FYI : the upper ball joint has an internal Hex )
and support the the knuckle and lower ball joints so that the brake lines dont get stretched out !!!
