Which Speaker Setup
mattd
i'm going to put new speakers in my 2000 sierra 1500 ext. cab. i'm not really that into music but sometimes i hear a song i want to turn up a little. anyway not planning on doing anything beyond new speakers. my question tho is what setup.....
new polks up front and back. FRONT and BACK. it looks like there are factory tweeters there now, too.....is that correct?
or
some COMPONENT setup just in the front and fade out the backs.
or
hey man this weekend i just installed 6.5" crossfire components with 75 watts rms going to each speaker, from my 4 channel amp and it sounds amazing. i can actually hear the music now, well i did blow both factory speakers..lol. What i did is removed the door panel:
check this out http://chevytruckworld.tenmagazines.com/ew..._2000_silverado
i had to modify the door panel a lil bit. cutout the hole a bit bigger and mounted the mid right in the door panel instead of the door itself. removed the factory tweeter mount (about a 3"x4.5" plastic piece with a small ass tweeter in the middle)and cut a 2-1/4" hole in the plastic and flush mounted the new tweeter in the old tweeter plastic mount.
Granted this is a bit of work and the fiberglass door panel cutting made for an itchy night but it sounds really good and still looks factory/stealth.
the rear speakers were 4x6.... didn't see that coming. now i just have to get in those 5-1/4" components somehow :)
or
If you're really not into music that much and only occasionally turn it up, you'll get by far the most bang for your buck installing those new Polks up front. They'll be so much more efficient than factory, that you won't even have to fade the back much - that's my current setup. Installation of those front speakers is a bit of a hassle, because GM uses proprietary mounting for their custom made speakers. The tweeter is in the door panel, and you can just disconnect it and leave it there if you want to. If you don't want to make your own adapter to mount the 6 1/2" coax into the door, Crutchfield ships speakers with a plastic adapter that will make installation very easy.
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
    • Pretty easy to just remove/drop the exhaust behind the manifolds. They're in no way hard to get to. Maybe 5min of work, and you get the opportunity to put some anti-sieze on them in case anything ever comes up, you eliminated the risk of snapping a stud.
    • I let the dealer do every other oil change simply so they can rotate the tires, which is a pita at home.
    • I addition, I won't have a pan full of fluid sloshing around to get all over the place.   I am putting on the Dorman pan with the drain plug. It looks like it is around the same height. I have one of these guys to make life a lot easier.   https://www.amazon.com/dp/B09CDXJCCT?ref=fed_asin_title&th=1
