Ac/heater Does Not Work!
Hello everybody,
I have a 1999 GMC Z71 1/2 ton p/u and my air conditioner and heater both do not work. No cold air or hot air but still blows air (even at different speeds). I already replaced the ac/heater controller on the dash and did not help. Has anyone ran into this type of problem and know of any solutions. Please help me out, summer is around the corner and I live in Phoenix, AZ. Thanks. Randy.
This may help out:
gmLogoFlat.gif Service Information
1999 GMC Truck GMC K Pickup - 4WD | Escalade, Pickup (Classic), Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 427298 Heating Insufficient <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=427298&pubCellSyskey=49442&pubObjSyskey=427298&from=sm&cellId=49442#ss1-427298">
Diagnostic Aids
The most likely causes of insufficient heating outside the heater system include a low coolant level, a faulty thermostat, a partially or fully clogged heater core or hose, an obstruction to the air circulation, or an air leak past a faulty seal into the passenger compartment. For the proper temperature verification, use the Tech II.
Step
Action
Value(s)
Yes
No
Inspect for the following conditions:
• A leak in the cooling system
• A low coolant level
• A loose belt or a worn belt
• A leaking heater hose or a kinked heater hose
• The loss of the radiator cap pressure seal
• The proper engine temperature thermostat operation.
Does the malfunction still exist?
Go to Step 2
System OK
2
  1. <LI type=1>Adjust the heater controls to the following modes:
The HEATER mode
The blower speed control to the HI position
The full WARM mode
<LI type=1>With the ignition switch in the ON position, inspect the airflow out of the floor air outlet.
Inspect the outlet attachment.
Is the airflow high?
Go to Step 3
Go to Step 6
3
Does the airflow change with different blower speeds?
Go to Step 4
Go to Step 10
4
Perform the heater output temperature check. Refer to Heater Output Temperature Check in Heater and Ventilation (Non-A/C).
Is the heater output temperature correct?
Go to Step 5
Go to Step 11
5
  1. <LI type=1>Inspect the following areas of the vehicle for cold air leaks:
At the cowl
In the heater case
In the vents
<LI type=1>Inspect under the seat for any obstructions.
Correct any conditions as necessary.
Is the repair complete?
System OK
6
Perform the function test. Refer to Functional Check .
System OK
Go to Step 7
7
Check the airflow from the vent outlets.
Is the airflow from the vent outlets high?
Go to Step 8
Go to Step 16
8
Move the defroster and/or the vent valve to the HEATER mode.
Is the defroster airflow correct?
Go to Step 9
Go to Step 17
9
  1. <LI type=1>Remove the floor air outlet. Refer to
Floor Air Outlet Replacement in Heater and Ventilation (Non-A/C). <LI type=1>Inspect for any obstructions.
Change the blower speeds.
Go to Step 8
Go to Step 10
10
  1. <LI type=1>Inspect the following parts:
The motor blower switch
The blower motor resistor assembly
The blower motor wiring harness
<LI type=1>Repair any conditions as necessary.
Go to Step 5
Go to Step 11
11
  1. <LI type=1>Turn the temperature rotary knob to full HOT.
  2. Inspect the temperature cable indexing.
Is the temperature valve fully closed?
Go to Step 12
Go to Step 21
12
  1. <LI type=1>With the temperature valve in the full WARM position, start the vehicle.
  2. Inspect the air temperature around the heater inlet and the heater outlet hoses.
Is the air temperature around both hoses at least at the specified value?
24°C (85°F)
Go to Step 13
Go to Step 22
13
  1. <LI type=1>Remove the hoses at the heater core.
  2. Inspect the hoses for proper installation.
Were the hoses properly installed?
Go to Step 14
Go to Step 24
14
  1. <LI type=1>Backflush the heater core. <LI type=1>Drain and replace the coolant. <LI type=1>Start the vehicle (Retest at less than ot equal to 30 psi).
  2. Inspect the air temperature around both hoses.
24°C (85°F)
Go to Step 15
Go to Step 22
15
Replace the heater core. Refer to Heater Core Replacement in Heater and Ventilation (Non-A/C).
System OK
16
  1. <LI type=1>Turn the mode knob to the DEFROST mode.
  2. Inspect the airflow.
Is the defroster airflow not present or low?
Go to Step 17
Go to Step 9
17
Go to Step 18
Go to Step 10
18
Inspect for airflow obstructions at the blower inlet and plenum.
Did you find and correct a condition?
System OK
Go to Step 19
19
  1. <LI type=1>With the blower in the HI mode, turn the temperature rotary knob from the full HOT position to the full COLD position.
  2. Listen for a change in the airflow.
Is a change in the airflow audible?
Go to Step 20
Go to Step 25
20
Check for an airflow obstruction between the blower and the system outlets.
System OK
21
  1. <LI type=1>Re-index the cable.
  2. Inspect the temperature valve adjustment, cables and linkage.
System OK
22
Check the thermostat for proper installation and sealing.
Is the thermostat properly installed and seated?
Go to Step 26
Go to Step 23
23
Reinstall the thermostat.
Go to Step 12
24
Properly reinstall the hoses.
Go to Step 12
25
Inspect the following components:
• The temperature valve
• The control assembly
• The blower motor wiring harness
System OK
26
Replace the thermostat.
System OK
© 2008 General Motors Corporation. All rights reserved.
