Edge Or Predator
I know this has been asked many times and i am sorry for this.
What is an advantage or disadvantage of one or the other. I know a tune like nelsons or them is better but i decided to just buy a handheld. Which one adds more power. Can you make a cusom tune for either one.Which one helps most to get rid of torque management. IT IS FOR A 2007 Chevy NBS 5.3 Thanks
Contact Jesse Bubb at Wait4Me. He will be getting a SCT programmer in for our trucks shortly that will store 3 tunes. That is what I am waiting for. You can switch back and forth to whatever tune you want.
Hey man sorry to be the first one to tell you this but, i got a wheatley 91 octane tune for $400 shipped. sent me a programmed pcm, just swapped with my stock pcm and what a difference! I'm not trying to tell you what to do as its your truck but i think a custom tune will get a few more horses. Just my 2cents. If you're opting for handheld i could suggest hp tuners as well... just use your laptop.
But the Edge does NOT remove ANY TM or other Nannies. The Diablosport does, but as of today, it does not tune the TCM in the GMT900's (last I heard).
Rethink your decision and get a custom tune!!! I have had both (sold my Edge). Trust me, there is NO comparison.
I suggest getting a laptop and a copy of HP Tuners and a Nelson tune. Then you have the best of ALL worlds. Tunes E-MAILED to you, and the luxury of going back and forth with no need for spare modules or a handheld. Plus you can learn how to tune!! HP Tuners is going to be my next purchase.
I'm considering getting the Edge one myself, I like the outlook monitor...Did consider getting a custom tune but personally I don't care about torque management or any of that BS, I don't need to be burning up 500 bucks worth of tires every time I go around the corner.
Then what do you want out of the Edge? Just the PID displays? You can get a ScanGuage for a hell of a lot cheaper than an Edge.
Oh, and removing TM and the Nannies is for DRIVEABILITY (throttle response), not for burning up the tires. I don't do burnouts with my truck, but it sure is nice knowing that is now MY decision, not GMs.
100% correct... that would be the U7194. They are still "working on" torque management.
All advice above (quote) is excellent advice.
I, personally, have a predator --- I have a custom 93 tune pushed via my predator. The boxed tunes weren't terrible at all. The custom tune does go the extra mile.
As with ANY tune, it makes a HUGE difference if you have 93 Octane available in your area. Timing is everything..... well 90% of everything. Removing the throttle delays and all of the nanny-cams is worth a lot too.... but in the end, it's the timing you can give back to the engine via the highest octane available.
Cheers !
Ohh, this issue is becoming a can of worm - all depends on what you want .. for a milder upgrade - a hand held ( i have the Edge ) will give your truck a little more life ,, if you want a little more extreme - then go with a PCM upgrade such as Nelson, Wheaty , Wait4me and BlackBear ,,
i play on the side of caution - if i take my truck in, i would like to have my truck returned to stock , yes you can also buy stock ECM / PCM units and swap them out
the arguement ' my dealer doesn't ... " yeah, but i dont live in WI or MA, i live in WA and my dealer does ..
do you want the 'mild' or the 'hot' sauce ??
