100,000 Mile Maintenance
My 2000 Silverado is about to roll over to 100,000 miles.
I actually just had to replace my fuel pump..... $360!! Plan on changing the fuel filter soon as well.
I have replaced the fuel filter and spark plugs at about 75,000.
I now plan on replacing the coil packs and o2 sensors. I usually like to go with OEM brands but I thought I would see what everyone else uses... any good or bad brands out there?
I am also planning on flushing the transmission and replacing the filter and putting new lubricant in the transfer case and rear differential.
I think this may get pricey when its all said and done.
What else should I do?
Any ideas/recommendations/opinions are greatly appreciated.
For the O2 Sensors use AcDelco/GM only.
On the fuel filter write the mileage and date on the can AFTER installation.
If you really want to flush the trans, the better machines do a 2 second reverse flow.
Install a Goodyear Gatorback s-belt.
My 2¢
Might I ask why you are replacing the coil packs?
Unless it is having soe issues with the ignition system I don't know why you would do this. Unless there is something I don't know replacing the coil packs is not part of the 100,000 mile maintenance.
The OEM ones range from $30 to $65 depending on which ones you get. Your looking at between $240 and $520 to replace things that may not be bad.
I have 3 service & 1 personal truck all are the same 2000.01,03 & 04 the olsdest has over 245000miles and still running strong. Coils are OEM original. If its not broke why fix it.
Well, they may not need to be changed. I was just assuming they needed to be.
The engine does have a little stumble in it while idling. I was thinking changing the coil packs would help.
You should probably test the coil packs before you spend a bunch of money to replace them.
I like that idea, how do I go about doing that?
Brad,
Not sure where you are located, but if you have a CARQUEST Store in your market, we use 3 OE suppliers, Denso, NTK and Bosch for our O2 sensors. Our cataloging will list the OE brand. I think your 2000 model had NTK O2 Sensors.
Just google "coil Tester" and you see a range of products that will accomplish the job.
Sounds ok, but has your transmission been flushed before? Often people start having problems with their trannys after flushing for the first time ever when the truck has 100k+ on it
It's like kicking a sleeping dog.
So I shouldn't have it flushed and change the filter?
Do you plan on keeping the truck awhile?
If so, then DO IT !!!
Just be sure to use a reputable transmission shop.
Not a brake shop that does transmissions.
Not a muffler shop that does transmissions.
A transmission shop that does transmissions.
Preferable one that does their own in-house rebuilds.
A lot can be "read" as to what has been going on inside the transmission when the pan is dropped
the only times Ive heard of that happening is if theyre already having Transmission problems. Its happened to me twice!! My old truck, an 88 silverado needed a rebuild after the trans started missing 2nd gear after a flush at 180,000 Miles.
Now take my 95 silverado company truck that has had 157,000 hard miles put on. I had the tranny flushed 5000 miles ago and its going strong, They told me the original fluid was like mud!
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
