I do believe you'd get your ass kicked around here for doing that to someone's truck. Everyone has a truck where I live and it would be taboo to mess with anyone's property.
  • Replies 391
Top Posters In This Topic
I wanted to ask if this messes up the paint. Thanks. :shakehead:
Yes it will mess up your paint, that stuff etches right into your clearcoat. I know from personal experience, my last Jeep Wrangler got covered with the stuff while I was at work. You could still see the lines in the paint after it was removed and washed many times. Clay bar did nothing. The only way to get rid of the lines is a good quality polish, I used an orbital buffer to get it out.
Your truck might be screwed though being a darker color, my Jeep was red. If you want some decent quality polish recomandations hit me up with a PM.
Edited by Dana_15
Dude, I think you need some therapy.
So you're okay with people throwing their trash into the bed of your truck.
I'm not sure I'M the one who needs therapy. What would you do if you caught someone throwing their soda cup into your truck, calmly go over and discuss other places they might throw their trash? Man, please.
You should have ordered this option <<<
:lol: But seriously that sucks. Make sure you videotape the revenge.
Yeah man that sucks. Somebody at my school thinks the bed of my truck is a trashcan because I keep finding their Chic-fil-a bags and half empty drink cups when I walk back to my truck after rugby practice.
People have a lot of guts to do that. I had a cover on my truck so I didn't happen to me. But I did have chewing tobacco thrown on my truck. One guy i knew had a milkshake thrown on his truck, the guy then poured brake fluid on his vehicle.
Thats exactly what i would do. Much better option then throwing a hissy fit and doing somethign you can get charged for.
+1
Thats the best non-reply so far in this thread. :lol:
well the first thing i would do is laugh and joke about it to people acting like it is no big deal. Then maybe it will get back to them that you don't really care and someone will tell ya who did it thinking you really don't care then WHAMMY superglue every lock on there car hoping they don't have keyless entry get there email and address and have all kinds of shit sent to there house.
+1
LAME
+1
Thats the best non-reply so far in this thread. :D
LAME
And that's the worst. :D
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
