  • Replies 391
Top Posters In This Topic
and I can't figure out how to rotate this one. But here it is anyway
Edited by Supertruck
Wow Marko,
That place is friggin beautiful. That last picture reminds me of when I was stationed in Montana. Glacier National Park was awesome.
There were 2 on here last night who are familure with plastic women.
Sometimes plastic women are cool. They don't bitch at you for being late or forgetting their birthdays. :crackup:
Hey Don, I just read some of your info. 3/5 CAV is the shiznit! I met some CAV guys when I went on the annual Memorial Batann Death March back in 2006. My USAF Squadron back in 2003 had a Black Knight as its mascot. My last squadron before I retired was a Spartan. The whole damn unit went to watch the movie 300 when it first came out. My commander basically rented one of the screens in the movie theater so no one but us Spartans were in there watching the movie. Everyone around there nearly shit when 250+ folks came into the theater wearing black unit T-shirts. :sigh:
Edited by GatorFan
Daddy,
That looks like the result of what would happen if your truck had sex with a Hummer. :crackup:
Heeh Heeh Heeh, You said Hummer :sigh:
Daddy,
That looks like the result of what would happen if your truck had sex with a Hummer. :lol:
Heeh Heeh Heeh, You said Hummer :lol:
I just now noticed how it matches the Biffy. Coincidence? I think not!!! :crackup::sigh::D
(Even the roofs are both white)
Edited by VMax2007
Daddy,
Hummer...Like nothing else!! :D
Daddy,
Huh? Just because your son would post pictures of Toyotas here doesn't mean everyone else would just for the hell of it. :lol:
I actually had a reason. I've never heard of it being called a Biffy. Please explain.
http://www.biffsinc.com/
Is that your vacation home? I don't get it?
J/K, I see now. We call ours honey pots, or port-a-pots, or Jeffs. :crackup:
Yeah I spent 1969 in Vietnam with the 3/5 cav. It was May 10-20 AShaw Valley. western Thau Province, I Corps. Operation Apache Snow, hill 937 know as Dong Ap Bia or Hamburger Hill. I believe they made a movie of the operation.
The 3/5 Cav received a Presidential citation for our participation.
I still have my original Black Knights cavalry scarf.
I could have been affected by Agent Orange, I know both my kids were born naked???
If you ain't Cav you ain't S__T
Don
Edited by dlstewart01
Wow Marko,
Thanks! I love it here.
BTW Whitefish is about 60 miles down the road from here. Anyone going through Whitefish must go to the Bulldog for a burger and a beer. Best place there is.
Anyone going though Fernie has to stop in for one.
    • @newdude great info, thank you!   So opening the thermal bypass valve early (or all the time) would cause temperature to rise more slowly, but above 194F there would be no difference from normal operation?   It seems like the only practical ways to bring down the peak temperature would be to improve the oil-air heat exchanger in some way or increase fluid capacity?
    • I have a trailer lights checker I plugged into the 7 way connector in the bed of my truck that has the 5th wheel/gooseneck hitch. It gave the camera side view with the turn signal on just like having a trailer connected but it disabled the rear bumper sensors. I would rather have the rear sensors working.
    • You are winning more than battles. You're winning the war!  Nice.
    • Blazer is all put back together. Another hard-won battle. The 4.3 is not easy to work on in such an archaic and narrow chassis originally designed for an inline 4.   My baffle issue is solved. I returned to the OG junkyard but was ready for a fight. The Blazer I had picked from was stacked on another vehicle so I had no idea how the heck I was going to get myself to working height to pull the front end apart. I had seen an S10 pickup on the ground so I was hoping the part would be the same, AND, I couldn't remember if the S10 still had a front end or not. But I didn't need to worry because it turned out to be my lucky day. The yard had just taken in a '98 Blazer, sitting right up front, on the ground, with room to work around it, and the front end hadn't been hit. The baffle and all the clips were factory perfect. I also scored another good handful of odds/ends and the whole shebang only cost me $20.   Got everything back together and it fired right off, sounds good, runs good. I've got a little coolant drip from a lower water pump bolt (D'OH!!). I did the right thing and snugged it down a little bit, and of course that didn't fix it. Yet again, I will have to soak everything in coolant to drain it down to the water pump, remove the bolt, and attempt to re-seal it. Nothing is easy on this truck. Nothing. But now all the radiator plastics are correct, snug, and fully functional. No more rubbing on the cooling fan. It runs, drives (took it for a 30 mile drive last night), no Check Engine lights, EGR is working, no vacuum leaks. We're getting closer...   The replacement wiper motor arrived yesterday. The tailgate was already disassembled and waiting, so I threw that in. It works! Sort of. Two new issues on the list. While the motor is strong enough and the gears aren't stripped, the wiper is hanging up on the bottom of the rear glass. This is the old style where the lower half folds down like a truck tailgate, and the glass swings up, and they meet in the middle when closed. The glass isn't sitting flush with the tailgate, now that I look at it. No rubber bumpers that I can see for adjusting, so I'll have to look at the hinge adjustment to see if I can correct it. Also, the washer/squirter just dumps fluid underneath the truck. The lines actually run inside on the floor so I'm guessing the tailgate is soaked at the rear trim and the line is disconnected. There's also a drain there....probably for this reason.   The leaky water pump bolt was really disappointing. JUST STOP LEAKING...OMG!!   Replacing the window motor and a rear door speaker are still to do, and then everything will work. I want this to feel like a "good" vehicle worthy of dropping $600 for new tires before I do. That means no leaking first. I hurt, and I'm kind of cranky, so I'll probably take a day of rest and do the water pump again tomorrow.
    • Just saw on Jay Leno the new Scout. That’s the way it should be done.
