2008 Remote
Sorry if this has been posted elsewhere, but I'm wondering if I could use the 2008 remote (with the 1000' remote start) with my 2006 Z-71? Thanks, saw this in Trucks TV and thought it was cool.
No, you can't use them on any truck because they're not available yet! There's a 9 page thread the full size light duty room about this remote (I assume you're talking about the 2 way remote). GM has yet to release it. There are aftermarket remote starts that do the same thing you could use. As far as being available for your truck once they're released, try posting in the other thread; it get's much more traffic than this room.
http://www.gm-trucks.com/forums/index.php?showtopic=68420
    • So, my 2021 only gets radio updates, right? If that's the case, my radio is doing just fine and probably better off without any updates, especially considering the problems I've been reading about after updates were performed.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
