Squeeking Shocks
I have had a slight squeek coming from one of my front shocks & has steadily gotten worse. Is this an indication it is about time for new shocks?
Pretty much, there is an easy way to tell. Take them out one by one and compress them. If they make noises, leak, or dont smoothly expand then they are bad. Recently i changed mine out for Monroe Reflexes from Napa. Although there are some benefits like smoother highway travel, they are really stiff off road. The truck does feel a bit more "planted" to the ground. But sometimes id like a little float here or there, if i wanted chronic back pains and neck join problems I would have bought a Dodge.
If I have to pull them off just to check them, they will get replaced! Truck is nearing 100,000 miles on the original shocks so it probably about time anyway. I just can't see going through the trouble of removing them just to put the old ones back on.
If you have 100K on a set of factory shocks in the state of Louisiana they're way overdue for being replaced.
Or it could be this,We've seen a few here at the dealership.....
Service Information 2002 Chevrolet Chevy K Silverado - 4WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1736787
#03-03-08-002B: Rattle/Squeak from Front of Vehicle (Replace Lower Portion of Upper Insulator Assembly) - (Nov 30, 2005)
Subject: Rattle/Squeak from Front of Vehicle (Replace Lower Portion of Upper Insulator Assembly)
Models:
2002-2005 Cadillac Escalade, Escalade EXT
2003-2005 Cadillac Escalade ESV
2000-2005 Chevrolet Silverado, Suburban, Tahoe
2002-2005 Chevrolet Avalanche
2000-2005 GMC Sierra, Yukon, Yukon XL
Condition:
Some customers may comment on a rattle or squeak type noise coming from the front of the vehicle.
Cause:
The front shock absorber plastic pilot ring may be wearing out, causing the shock to misalign in the insulator.
Correction:
DO NOT replace the shock . Replace the lower portion, P/N 15834275 , of the upper insulator assembly using the procedure listed below. This new insulator has a taller plastic pilot ring that is attached to the metal sleeve to aid in the proper alignment of the insulators.
Remove the front shock absorber. Refer to the Shock Absorber Replacement procedure in the Front Suspension sub-section of the Service Manual.
Remove the lower portion of the upper insulator from the shock and discard.
Install the new lower portion of the upper insulator to the shock.
Important: Be sure to center the shock in the frame bracket and tighten the upper mounting nut when the vehicle is on the ground.
Install the front shock absorber. Refer to the Shock Absorber Replacement procedure in the Front Suspension sub-section of the Service Manual.
Parts Information
Part Number
Description
15834275
Insulator Asm. - Frt. S/ABS (Lower Part of Upper Insulator)
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
  • 4 months later...
So I have a squeaking from the front end of my truck. Based on reading the above TSB...I don't understand fully what you are supposed to do. But, if I replace the front shocks will I also have accomplished the TSB fix above?
Hey everyone. im new to here and i've been having a squeeking problem with my truck. i have a 2003 Serra with the 5.3. and lots of upgrades to motor, trans and tires... So the problem i have is when i hit a bump it makes a loud squeek. i hear that is in the rear of my truck i know that cuz i replaced my fronts a couple of months ago. are my rears going bad now or what? and the other thing that just came is when i go in gear i hear i squeek with that... its not really loud or any thing... its more annoying than anything. can anyone help me?
At 100K you are long overdue for shock replacement. They get worse gradually so you really don't notice just how bad they really are until you install new ones! You'll probably think you bought a new truck.
thats the kicker im only at 68500.... far from 100k! i work construction and i tow alot... my work trailer and the one in the back of that pic but still
Could possibly be the shocks, but I think leaf spring/shackle bushings would be more likely.
hmmm never thought of that.....i'll have to get in and see what they say.... thanks man
ps nice truck
ps nice truck
Thanks, and right back atcha. :rollin: I like the headache rack.
Oh, welcome to the site.
ps nice truck
yeah i just took all the chrome and stickers off the entire truck a few weeks ago... i think it looks great with out stickers and chrome....
    mighty K20
    mighty K20
  • Who's Online   3 Members, 2 Anonymous, 452 Guests (See full list)
