Accessory Light Switch
05 GMC 2500...
I have the accessory light switch (near the airbag control on dash). ive heard the end of the wiring is located above the headliner on the driver side. i have a mini-bar on the roof for snowplowing....dont leave it up there all the time. any way to have a quick connect for the light so i can use the accessory switch??
The wires for the aux. light switch are deadheaded over the drivers
side under the headliner.
Don't forget you will/may need to put a maxifuse in stud position #2
in the underhood fuse center..................
Read this for the best ways to fish out the wires, what colors they are,
and pics of the different ways the snowplow boys ran theirs out of
the cab to power up their light bars and such:
http://www.letstalksnow.com/forums/showthread.php?t=9623
I have yet to dig mine out yet on my 07!........geo
