Thought Id Post
istabemos
Priceless :crackup:
There are other ones floating around here somewhere...If anyone knows where they are let me know. I want to save them. LOL
Yeah I use to watch that show but it just got dumber and dumber, racing is starting off even and not giving somebody 1-30 car head start. Plus them arguing back and forth got on my nerves.
I don't get the whole "lengths" deal
I just watched the episode with the 92 mustang vs. the 96 camaro, and the mustang was talkin' **** when he had a 3 car length head start
I don't know but I wouldn't give up my ride to someone who didn't start at the line with me.
I prefer the all out series as well, much more fun. But on these Pinks import vs domestic it's funny to watch Vtak getting it's noble and all powerful variable valve timing raped. I believe this is the episode:
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
