4x4 Drive Shaft
I just put my tranny back in and had to disconect the drive shaft for the front. the transmission mounts are lined up and eveything seems lined up right just the drive shaft is not connecting by like 2 inches
iam not sure if its just two inches short, in length ?? ,if this is what you mean, then when you place the end in the tranny and raise it up to connect to the rear end you can then just pull it toward the rearend until it connects, its not suppose sit all the way in on the tranny end,
did you change any tranny housing parts
No, no housing parts were changed
