Where Do You Guys Get The Info For A Vin Check
Happy Easter. Where do you guys get the info for a vin check. Just got an 03 Sierra Denali and was wondering what the build sheet/vin check would look like. Vin 2GTFK69U331177390. Also is there a list of option codes that one can look at to decipher the info.Thanks, Dave. P.S. still a newb here.
Welcom to the club.
As far as the VIN run goes some of the guys here have access to GM's system and can run it. I'm sure one of them will see this post and run it for you.
But if you want to know now you can look inside your glove box and on the door you will see a large sticker with a list of 3leter/number codes called RPOs. Their is a link to the left under the navigation headding call RPO Lookup.
Enyoy the new truck
At work right now, but I will look at the sticker in the glove box. No sticker on the door or jamb. Peeled off for some reason. Thanks and if anyone does have access to the data base that would be cool.
GM Vehicle Inquiry System
Summary
VIN : 2GTFK69U331177390
VEHICLE INFORMATION
Merchandising Model : TK15753 -2003 SIERRA DENALI AWD 4 DR PICKUP
Warranty Start Date : 01/07/2003
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer :
GROSSINGER AUTOPLEX
6900 MCCORMICK BLVD
LINCOLNWOOD , IL 60712-2775
(847) 675-8300
Selling Source : 48 - GMC TRUCK
Site Code : 26038
Business Associate Code : 119166
Service Contract : No
Branded Title : No
Warranty Block : No
PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 02066 BATTERY DRAIN N/A Closed
RC 04007 TAILGATE SUPPORT CABLE N/A Closed
SERVICE INFORMATIONAL ITEMS
SB 06047 ONSTAR HARDWARE CAN BE UPGRADED TO DIGITAL. SEE TSB 05-08-46-006. 02/21/2007
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes
OnStar Status Inactive
Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped No
XM Radio ID N/A
XM Status N/A
Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 01/07/2003 13 miles 01/07/2006 36013 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 01/07/2003 13 miles 01/07/2009 100013 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 01/07/2003 13 miles 01/07/2011 80013 miles
36/36000 FEDERAL EMISSION 01/07/2003 13 miles 01/07/2006 36013 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
07/06/2007 350955 J V0961 - 02066-REPROGRAM BCM 50642 miles
07/06/2007 350955 J V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 50642 miles
01/12/2004 058055 # E9740 - GEAR ASSEMBLY, POWER STEERING - REPLACE 19022 miles
01/12/2004 058055 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 19022 miles
05/30/2003 054324 # D1116 - SWITCH, COMPRESSOR CUT-OFF - HIGH PRESSURE - REPLACE 9072 miles
03/27/2003 053283 # F2142 - DIFFERENTIAL CARRIER ASSEMBLY REPLACEMENT 6443 miles
03/27/2003 053283 # Z7907 - COURTESY TRANSPORTATION - PARTS NOT AVAILABLE 6443 miles
03/27/2003 053283 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 6443 miles
11/04/2002 A77390 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
© 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
CLAIM HISTORY
Repair Order Date : 07/06/2007
Repair Order Number : 350955
Odometer Reading : 50642 miles
Serviced By :
SHEPARD CHEVROLET INC
930 CARRIAGE LN
LAKE BLUFF, IL 60044-2215
(847) 234-7900
Selling Source : 13 - CHEVROLET
Site Code : 11486
Business Associate Code : 113245
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
07/20/2007 814 01 J V0961 - 02066-REPROGRAM BCM N/A N
07/20/2007 814 02 J V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 88980509 - CBL-E/GAT N
Repair Order Date : 01/12/2004
Repair Order Number : 058055
Odometer Reading : 19022 miles
Serviced By :
SANTA FE PONTIAC BUICK GMC
2721 CERRILLOS RD
SANTA FE, NM 87507-2312
(505) 473-2886
Site Code : 42111
Business Associate Code : 166539
01/23/2004 450 01 # E9740 - GEAR ASSEMBLY, POWER STEERING - REPLACE 26102452 - S/GR REM Y
01/23/2004 450 02 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 26102452 - S/GR REM Y
Repair Order Date : 05/30/2003
Repair Order Number : 054324
Odometer Reading : 9072 miles
Serviced By :
2721 CERRILLOS RD
(505) 473-2886
Site Code : 42111
06/17/2003 387 01 # D1116 - SWITCH, COMPRESSOR CUT-OFF - HIGH PRESSURE - REPLACE 01132749 - SWITCH N
Repair Order Date : 03/27/2003
Repair Order Number : 053283
Odometer Reading : 6443 miles
Serviced By :
2721 CERRILLOS RD
(505) 473-2886
Site Code : 42111
05/02/2003 374 02 # Z7907 - COURTESY TRANSPORTATION - PARTS NOT AVAILABLE N/A Y
04/25/2003 372 01 # F2142 - DIFFERENTIAL CARRIER ASSEMBLY REPLACEMENT 15164179 N
04/25/2003 372 03 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 15164179 N
Repair Order Date : 11/04/2002
Repair Order Number : A77390
Odometer Reading : 0 miles
Serviced By :
GROSSINGER AUTOPLEX
6900 MCCORMICK BLVD
LINCOLNWOOD, IL 60712-2775
(847) 675-8300
Site Code : 26038
11/08/2002 324 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
Vehicle Build
VIN 2GTFK69U331177390
VEHICLE BUILD
Gross Vehicle Weight Rating : 3269 kg (7208 lb)
Order Number : FQJZ8K
Build Date : 11/04/2002
Build Plant : 23153
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AG1 - POWER DRIVER SEAT ADJUSTER
AG2 - POWER FRONT SEAT ADJUSTERS
AJ1 - DEEP TINTED GLASS
AL0 - SENSOR INDICATOR, INFLATABLE RESTRAINT
AM7 - FOLDING REAR SEAT
AN3 - FRONT FULL-FEATURE RECLINING BUCKET SEATS
AU0 - REMOTE KEYLESS ENTRY SYSTEM
AU3 - POWER DOOR LOCKS
A31 - POWER WINDOWS
BS1 - INSULATION ACOUSTICAL PKG
BW2 - DELUXE BODY SIDE MOLDINGS
B30 - FULL COLOR KEYED CARPET W/MATS
B58 - FRT & CTR CARPETED FLOOR MATS
CJ2 - AIR COND., DUAL ZONE AUTOMATIC
C49 - ELECTRIC REAR WINDOW DEFOGGER
C5Z - GVW RATING - 7,200 LBS
DF5 - ISRV MIRROR W/COMPASS & TEMP
DH2 - ILLUM LH & RH VISOR MIRRORS
DK7 - CUSTOM INTERIOR ROOF CONSOLE
DL3 - EXTERIOR MIRROR W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ, HEAT, TURN SIGNAL &GROUND ILLUMINATION
D07 - FLOOR SHIFT CONSOLE
EVA - EVAP EMISSION REQUIREMENT
E63 - WIDESIDE BODY
E95 - RR COMPARTMENT TONNEAU COVER
FE9 - FEDERAL/NY/VT EMISSIONS
FF6 - TORSION BAR SPRING ADJ - LH
FF7 - TORSION BAR SPRING ADJ - RH
GT5 - REAR AXLE - 4.10 RATIO
G80 - LOCKING REAR DIFFERENTIAL
G86 - LIMITED SLIP DIFFERENTIAL
JC4 - HEAVY DUTY POWER DISC BRAKES
KC4 - ENGINE OIL COOLING SYSTEM
KG3 - ALTERNATOR 145 AMP
KNP - H.D. TRANSMISSION OIL COOLER
KUP - THROTTLE CONTROL ELECTRONIC
K34 - ELECTRONIC SPEED CONTROL
K47 - HIGH CAPACITY AIR CLEANER
LQ4 - VORTEC 6000 V8 SFI GAS ENGINE
M32 - 4 SPD AUTO TRANS, ELECTRONIC
NA1 - EMISSION SYSTEM - LIGHT DUTY
NF2 - FEDERAL EMISSION SYSTEM
NP3 - ALL WHEEL DRIVE TRANSFER CASE
NP5 - LEATHER WRAPPED STEERING WHL
NYS - *QUADRASTEER
N93 - 17" 6-SPOKE ALUMINUM WHEEL
OSG - ASSEMBLY PLANT, OSHAWA, ONTARIO
QAN - P265/70R17 ALS BW TIRES
R4Y - TIRE BRAND ALL GOODYEAR
R8Q - ILLINOIS SURCHARGE
R9Z - POMS EXPEDITE-SOLD ORDERS
SAF - SPARE TIRE LOCK
SLM - STOCK ORDERS
TFE - SALES INCENTIVE-COMMITMENT PLUS
TL1 - DELUXE GRILLE W/COMP. HEADLAMPS
T96 - FRONT FOG LAMPS
UB1 - AM/FM STEREO W/CD/CASSETTE AND BOSE SPEAKER SYSTEM
UE1 - ONSTAR COMMUNICATION SYSTEM INCL 1 YR SAFE & SOUND PLAN
UG1 - HOMELINK UNIVERSAL TRANSMITTER
UK3 - STEERING WHEEL RADIO CONTROLS
UK6 - REAR SEAT AUDIO CONTROLS
UQ7 - BOSE SPEAKER SYSTEM
U01 - ROOF MARKER LAMPS
U1S - 6 CD CHANGER
VK3 - FRONT LICENSE PLATE MOUNT
VP6 - NOISE CONTROL
VR4 - WEIGHT DIST HITCH PLATFORM
VT4 - BUMPER FRT COLOR KEYED
VT5 - BUMPER RR COLOR KEYED
VXS - COMPLETE VEHICLE LABEL
V73 - STATEMENT OF CERT. U.S.
XAN - P265-70R17 - 113S BW FRONT
YAN - P265-70R17 - 113S BW REAR
YD3 - BASE EQUIP FOR SCH GVW PLATE
YD6 - REAR SPRING - BASE EQUIPMENT
YE9 - SLE/SLT DECOR
Y91 - DENALI PACKAGE
ZGC - P265/75R16 BW SPARE TIRE
ZX3 - RIDE CONTROL-MANUAL SELECTABLE
ZY1 - SOLID PAINT
Z82 - HEAVY DUTY TRAILERING EQUIPMENT
Z88 - GMC TRUCK NAMEPLATE
1SE - DENALI DECOR: ULTIMATE IN PROFESSIONAL GRADE *AIR COND., DUAL ZONE AUTOMATIC *POWER WINDOWS & DOOR LOCKS *REMOTE KEYLESS ENTRY *CARPETED FRT & REAR FLOOR MATS *REAR WINDOW DEFOGGER *FOG LAMPS *EXTERIOR MIRROR W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ., HEAT, TILT, TURN SIGNAL & GROUND ILLUMINATION *17" 6-SPOKE ALUMINUM WHEELS *HEAVY DUTY TRAILERING EQUIP *BODY COLOR TONNEAU COVER *ROOF MARKER LAMPS *ONSTAR COMMUNICATIONS SYSTEM INCL 1 YR SAFE & SOUND PLAN *HOMELINK UNIVERSAL TRANSMITTER *LTHR WRAPPED STRG WHL W/TILT *AM/FM STEREO W/CD/CASSETTE *6 CD CHANGER *BOSE SPEAKER SYSTEM *STEERING WHEEL RADIO CONTROLS *REAR SEAT AUDIO CONTROLS *CHROME TUBULAR SIDE STEPS ***DEALER INSTALLED***
1SZ - OFF-ROAD PKG DISCOUNT
11U - PEWTER METALLIC
6YT - COMPONENT FRT LH COMPUTER SEL SUSP
7YT - COMPONENT FRT RH COMPUTER SEL
92I - DARK PEWTER INTERIOR TRIM
922 - STONE GRAY INTERIOR TRIM
© 1998-2005 General Motors Corporation. All Rights Reserved. GM Vehicle Inquiry System
Vehicle Component
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : W - CPC/DDA ROMULUS, MICHIGAN
Part/Num Broadcast : FUH Traceability : 023045162
Date Scanned : 11/04/2002 Time Scanned : 18.11.00 Scan Station : 04
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : S - SAGINAW DIVISION SAGINAW,MI
Part/Num Broadcast : XTP Traceability : 662153022
Date Scanned : 11/04/2002 Time Scanned : 14.27.00 Scan Station : 10
Component Code : 50 - INSTRUMENT CLUSTER
Source Plant : 3
Part/Num Broadcast : DSX Traceability : DSX
Date Scanned : N/A Time Scanned : N/A Scan Station : N/A
Component Code : 60 - TRANSFER CASE (4 WHEEL DRIVE)
Source Plant : N
Part/Num Broadcast : TJ Traceability : 0AP173590
Component Code : 61 - TRANSMISSION
Source Plant : R - HYDRAMATIC THREE RIVERS, MICHIGAN
Part/Num Broadcast : 3KZD Traceability : 34989931
Component Code : 63 - FRONT AXLE/FRONT CRADLE WITH FRONT HUB ASSEMBLIES
Source Plant : G
Part/Num Broadcast : TUH Traceability : N011676
Date Scanned : 11/04/2002 Time Scanned : 18.33.00 Scan Station : 05
Component Code : 65 - REAR AXLE ASSEMBLY
Source Plant : S - DANA SYRACUSE, INDIANA
Part/Num Broadcast : GZ7 Traceability : S240A024V
Date Scanned : 11/04/2002 Time Scanned : 18.30.00 Scan Station : 07
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : 9
Part/Num Broadcast : YCTJ Traceability : 22301GS5Z
Date Scanned : 11/04/2002 Time Scanned : 21.38.00 Scan Station : 03
Component Code : 87 - BODY CONTROL MODULE
Source Plant : M
Part/Num Broadcast : 4169 Traceability : 22298CVZV
Component Code : 92 - BRAKE PRESSURE MODULATOR VALVE ASSEMBLY
Source Plant : K - KELSEY-HAYES JASPER, INDIANA
Part/Num Broadcast : 5219 Traceability : 00000767
Date Scanned : 11/04/2002 Time Scanned : 18.19.00 Scan Station : 09
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : Q - RIMIR MATAMORS MEXICO
Part/Num Broadcast : 5376 Traceability : 9CDCETH
Date Scanned : 11/04/2002 Time Scanned : 19.47.00 Scan Station : 11
Component Code : AH - IR-SENSOR ASM-LEFT
Source Plant : V - DELCO ELECTRONICS REYNOSA MEXICO
Part/Num Broadcast : 7506 Traceability : 2290HC26T
Component Code : AJ - IR-SENSOR ASM-RIGHT
Part/Num Broadcast : 7506 Traceability : 2290HC1HR
Component Code : AL - IR-MODULE ASM-I/P
Source Plant : M - MORTON-THIOKOL
Part/Num Broadcast : 2349 Traceability : 8WAMP85
Date Scanned : 11/04/2002 Time Scanned : 14.27.00 Scan Station : 01
Component Code : AS - SENSING DIAGNOSTIC MODULE
Source Plant : K - DELCO ELECTRONICS KOKOMO,IN
Part/Num Broadcast : 2446 Traceability : 1230463JA
Component Code : BX
Source Plant : S
Part/Num Broadcast : 7856 Traceability : 122100072
Date Scanned : 11/04/2002 Time Scanned : 18.57.00 Scan Station : 06
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 199 Traceability : 0861079
Date Scanned : 10/29/2002 Time Scanned : 23.02.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 133 Traceability : 4103899
Date Scanned : 11/04/2002 Time Scanned : 13.46.00 Scan Station : N/A
Delivery Information
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 01/07/2003
Delivery Type : 021 - GMO EMPLOYEE OUT-OF-STOCK/OPTION 2
Delivered Odometer : 13 miles
Delivering Dealer :
GROSSINGER AUTOPLEX
6900 MCCORMICK BLVD
(847) 675-8300
Delivery Selling Source : 48 - GMC TRUCK
Delivery Site Code : 26038
One more question. For my truck it shows rpo G80 and rpo G86. Granted mine is AWD but I thought they only used these in the rear axles. I have quadrasteer. I doubt it has a limited slip in the front. What do you guys think. Dave
    • Follows the motif on the Sierra EV.  Satin finsh to the lower bumper area, painted above:   Elevation       Denali
    • Not exactly what I was hoping for, but I do like it. I wonder if they'll bring back Smokey Quartz Metallic? 🤔 https://gmauthority.com/blog/2026/06/here-is-the-all-new-2027-gmc-sierra-1500/
    • Whoever greenlighted the work truck matte black front bumpers on every trim but the AT4X should be fired!  I was hoping that was an AI mistake, but just realized they were on every model of the 2027 Silverado too.     Some parts of the interior do look premium, but the Denali Ultimate dashboard looks like an afterthought.  At least they appear to have lost the microfiber the high end Silverado models showed, but the '27 High Country dash looks better than the Denali.
    • New member here. I am researching a read-first event-recorder concept for late-model GM V8 trucks. This is not a sales post. There is no product link, price, preorder, or mailing list. I am trying to determine whether the underlying problem is real before building anything.   Has your truck ever had a brief problem such as: - rough running or a momentary misfire - an oil-pressure warning or unusual pressure event - reduced power or a brief stall - a U-code or lost-communication problem - a symptom that disappeared before the dealer or independent shop could reproduce it   If so, I would appreciate the following details: - year, model, engine, and mileage - what happened and under what conditions - whether a DTC and useful freeze-frame data were stored - whether the shop was able to reproduce it - what the eventual confirmed repair was, if known - what additional information would have helped the diagnosis   The concept being evaluated is a removable leave-in recorder that continuously retains a rolling window from before and after an event. It would not tune, reflash, clear codes, or change the vehicle calibration.   I am also not claiming that it could predict lifter failure or see every internal ECM variable.   The real question is whether continuous event history would add enough useful evidence beyond freeze frame, GDS2, and existing scan tools — or whether it would simply be another unnecessary gadget.   For owners and technicians, which problem would make something like this genuinely useful: 1. intermittent misfire or AFM/DFM-related behavior 2. oil-pressure events 3. lost communication or electrical faults 4. none of the above Please be blunt. Negative feedback is just as useful as positive feedback.
    • No tears over the SLE and SLT trim levels disappearing but I kind of loathe the "Elevation" name. It's a truck--skip the elegance.   The slab-dashboard design is decidedly different. Almost has a Hummer flavor to it. "Professional Grade" seems to be leaning very white-collar, tech-driven these days moreso than blue-collar, functional design.   The Silverado would be my choice between the two new trucks. Pleased with the engine lineup in both. The GMC is a little "too much" for a truck, IMO, and the Denali borders on ridiculous - but I do know there are buyers for luxury trucks out there. It's just not my speed.
