Realtruck.com
RVJ
I ordered a Lund brand Hood protector, wind deflector from Realtruck.com on Thursday evening and paid for it Friday morning. I was told I would receive it in a week or so. It arrived today, 3 days after paying for it and 2 of those days were Saturday and Sunday. I am very impressed with the way these people strive to get your item shipped to you fast. Forgot to mention, since I had just made a previous order they gave me a $20.00 coupon which I used for this purchase. From now on, anything I want for my truck will be researched from there first. Until a couple weeks ago, I had never even heard of them, they are a favorite vendor for me now.
  • 4 weeks later...
Thanks fo the Kuddos!!
  • 1 month later...
Look nice! :D:lol:
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
