Extra Computer For My Truck
Hello, have been reading about the tunning options, and the possible problems with the dealer if they find a tune on my truck. So I am taking the advice of many members on this board, and ordering a computer for my truck, so that I can remove my stock computer(s), and install the mod on the "new" computers. I have a few questions.
What computer(s)do I need to order (ie. PCM, BCM....) ?
Where have some of you purchased your extra computers?
Average price for this computer?
Can I find the correct part number by simply looking at my stock computers, or will I have to go and ask a dealer?
Will the new computer need to be "reflashed", and how is this done?
Thank you in advance for your help.
-Al
Edit:
I have a 2008 Chevy Silverado 2WD LT Crew Cab with a 5.3 engine
PCM is all there is. Custom tune costs will vary depending what you have done, average is $300 - $450. I dont have a custom tune personally, but I have looked into it alot and have been considering. Blackbear, Westerns, & Wheatley seem to have the best tuning and most satisfied customers.
No the new 07 and up trucks have a pcm and a tcm. One for the trans and one for the engine!!
That is what I thought. I forgot to mention that I am doing this to a 2008 Silverado Crew Cab with a 5.3 engine.
part numbers:
PCM 12597121
TCM 24234503
Awesome, thanks for the part numbers. I will start looking for them online (maybe ebay) as other have done.
-Al
I get the feeling the demand will increase for these modules, given the info that is now circulating. I am wondering if the prices will start to rise on the modules.
Hey Will, has any of that info been on the DTC forum? I was wondering if Butch could validate any of it.
It would be nice to see what Justin had to say too...
Scott, you mean the "GM looking in to people tuning their vehicles and 86ing their warranties" story? If so, then no.
Yes, sorry I should have been more specific. Okay, thanks Will, I was just curious what they thought. I have been following that thread on the Corvette Forum
Here's what Butch had to say last time something like this came up. I think he makes some salient points:
GM just at the end of last year, and after a long court battle, has finally let the aftermarket into their SPS database, the complete database, not the aftermarket version we had to use before! So now that they were forced to do that, they come out with this!!
PITA, but we'll somehow get the tuning done! Every year we have to change, and find new ways to defeat this craziness. A well written tune, by someone that knows what they are doing will add life to the engine and drivetrain, even the GM engineers are on board with that. Unfortunately we have to suffer for the majority of tuners that do more damage than good! I know one that hurt 7 transmissions last year, simply from lack of knowledge. Making a truck go fast but ruining the transmission or hurting an engine is not quality tuning. GM engineers have examined many of these aftermarket tunes. I have sent some of the bad tune files to Lyndon and he has shared them with his GM engineer friends. They have also examined dozens of Lyndons tunes and even shared information. The engineers know factory tuning is very limiting, they also know that it can be improved, but cannot do it themselves since the stock programming must cover all worst case scenarios like bad gas and poor maintenance.
Maybe it's time for licensing? It's been talked about! Eliminating the garbage tuners and licensing the good tuners would do allot toward the war between the manufactures and the aftermarket.
Personally, I really like the idea of licensed tuners. Getting a tune from one of these people would not affect your warranty, and self-tuners who wanted to mess around could either run the risk of warranty problems or simply buy some spare modules. Seems like a smart and fair solution, but I doubt GM will ever go for it.
Definetely great information. I have been following the thread talking about voiding GM's warranty with mods, so I am going to do it the "safe way", and use a spare computer. OK, so I;ve got most of the information I need. Will, I will email (MiamiDenali), and see if he still has the computers available. I will also be checking eBay to see what they are going for there. Now, once I buy the computers, how do I get them reflashed? Do I install them, and then have the dealer reflash them, or do I take them to the service dept. and ask them to reflash them? Either way, what do I tell them if they ask me why I need an extra set of computers for my fully warrantied truck? Thanks for all the info. Keep it coming. I will be sure to document the process, and write a detailed writeup.
Thanks,
-Al
Thanks,
-Al
I'm not 100% with the NBS workings but you should just send the pcm to the tuner of your choice and they will tune it, then you swap them for the stock ones, simple plug and play, and keep the stock ones on a shelf in case you should need to reinstall it.
Thanks,
-Al
OK, is that how it works. I have heard other mention this "reflash", so I was assuming that they tuner needed to have some stock values on the computer in order to do a tune. Anybody else that has swapped ECM's to do a tune know if this is possible. That would make it a heck of a lot easier.
-Al
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
