05 2500hd Issues
Duse
Hello,
I have a couple issues I figure I would ask about before I took it to the dealer I bought it from.Of course the dealer will say "Thats normal" :shakehead:
#1, the exhaust pipe has a small pinhole crack in the weld that water comes out.
It's just atthe back side of where the 2 pipes turn into 1.
I noticed the water dripping out this morning.And I'v also been noticeing dish size spots in my driveway from where I let it warm up.
#2, The clear running light lens (front,passenger side) has condinsation in it?
#3, The Change oil light has been comeing on once in a while.
The oil was changed maybe 7-800 miles ago. I checked the dip stick and it was fine.
Any suggestions.
Thanks guys
Did you reset the oil light when you changed it? (turn the key to run without starting the truck, then depress the gas pedal to the floor 3 times within 5 seconds)
No I dident.Thanks for the tip.
The truck has 44000 miles on it,would there be a problem switching to snythetic now?
