Jegs.com
bigBP
Well, made my first purchase from jegs. Ordered a electrical wiring harness kit and some other odds and ends earlier this week. The prices were good but what really got me was the shipping. I ordered on a late Monday morning and the package arrived on my doorstep the next afternoon with their "standard" shipping :omg: . It's the quickest turnaround I've ever had on an order.
So, as of now, they get a thumbs up in my book :thumbs:
I guess I should give some props to fedex too :D
I bought my exhaust from them and had a very good experience. I called them to order it to make sure that everything was right, they were very friendly and very helpful. :lol: in my book.
I've used Jegs successfully for HotRod parts over the years... but I usually end up going to Summitracing. Both are staples of the performance business.
  • 1 year later...
I ordered a Banks Ram-Air system from them on Monday night, they had the order shipped VIA Fedex before sunrise Tuesday and the part arrived to me in Houston Wednesday afternoon. Awesome and that was with the free shipping.
I also odered a set of MSD plug wires, the site stated that they wouldn't be available for a couple of weeks, to my surprise they also shipped that same night and arrived with my CAI. Jegs.com :thumbs:
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
