Welcome snocross2001
chevy4x4trucks
Guest SiiLT_old
This is great.  Hopefully 2000 will come a little quicker. :sigh:
Quote from SiiLT, posted on Nov. 08 2001,10:37
This is great.  Hopefully 2000 will come a little quicker. :D
I remember about 10 months ago when there were more moderators than members...   LOL
This site is great and thanks to everyone who has made it as good as it is...
I don't think there is another GM trucks website on the net that has this many great members that really care about what they drive and want to help their fellow members out more than this one... (sorry about the run-on sentence... LOL)
Everyone here is awsome and thanks for your input!
:sigh:
Shane
