Radio Turning Itself On
SoCalChris
The last three mornings, when I've gone out to go to work, my radio has been on, and all dash lights are on.
My truck did this a few times over the past year, but is starting to do it more frequently now. Any suggestions about where to look? It's a 2006 Silverado, regular cab, work truck. The original AM/FM radio was swapped out for a GM 6 CD in dash changer.
Thanks
Thanks
Chris, I would start by checking all the connections for the new radio. A bare power wire or connector is touch another bare power wire or connector. If they replaced the radio with the CD changer and didn't need to splice wires, then it's a more difficult problem. But that's where I'd start.
On 2003 and up trucks, the radios don't have switched power leads, they are signaled to turn on and off using the vehicle's computer. Most likely, the radio is defective or the computer is telling the radio to come on when it shouldn't.
IMO, this is a good excuse to put a good aftermarket receiver in there!
I checked all of the connections, they're all good. The radio that I replaced the original with is a genuine GM radio, so it was all plug and play, no splicing.
I don't care for the looks of almost any aftermarket receivers, and I've already paid good money to upgrade to this radio. I don't think the radio is defective either, it seems like either an issue with the ignition switch or computer.
Yes, but if the ign switch is staying in the ACC position, then the power mode master will be telling the modules to stay on.
That happened this morning as I stopped for gas. I turned the truck off, removed the key, and opened the door. The radio, dash lights and guages all stayed on, like the truck was still running. Also, the amp that I have stayed on. The switched power supply that turns the amp on and off comes from the MID BEC connector behind my clutch pedal, so it seems like the truck thought that it was still on, even though it wasn't.
Should I take a look at the ignition switch? How hard is it to replace, and how much is it approximately? If it's not the ignition switch, what else should I look at?
Also, could this be related to a problem that I had this winter? Gauges Crapping Out In Extreme Cold
Thanks for everyone's help.
The switches are cheap, $40 or so. If you get the bottom of the column trim off, the switch is not hard to change, BUT the timing of the switch is vital. There are teeth as the ign switch and cylinder are meshed together with a gear system.
Thanks for the help. I found the part at a local dealer, and am picking it up today. Our local library offers a car repair guide online, so I got the instructions on how to replace it, and properly line up the gears. My only question is that the instructions show a special tool is needed to remove the switch. Is the tool really necessary, or should I be able to rig something up on my own to serve the same purpose?
Thanks again.
I replaced the ignition switch this afternoon. All said, it was a simple job, and will hopefully fix the problems that I've been having. I'll write up a how to for anyone else that has problems to refer to in the future. Thanks for everyone's help!
Well, that didn't work. I woke up this morning to a dead battery. Any suggestions on where to look next?
Well, If I was working on it, I would perform a parasitic drain test. Simply install an Ammeter in series of the neg battery cable. This should only be done after determining the drain is low enough to ensure the meter will handle it. If you want to attempt this, email me and I will send you much more detailed instructions and tips.
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
