Help With Hypertech Programmer Instalation.
aronbayev
I own a Hypertech Power Programmer III. I installed it in my Truck a 2002 S10 4x4.
It worked fine till I switched to 4x4 and drove for a while. The car was stuck in 4x4hi.
I broght it to the dealership and they changed the control module witch cost me $500,-.
All I did was to change shift points between 1 and 2 gear +300 rpm, 2 and 3 gears by +200 rpm, 3 and 4 gears by +100 rpm. The shift firmness I set to 50%. All other settings I did not change.
I am afraid to install the software again. What am I doing wrong?
Well, there's not a whole lot you can do to mess up the tuning process. Unelss maybe you pulled the cable before it was done... in which case you'd have far more serious issues.
But did you try or were you even able to return the vehicle to stock? And which control module did they replace? Was it the PCM? If not, I don't see how a handheld tuner would have caused another unrelated component to fail. And any time you suspecting a tune to be causing a problem... it's normally fairly easy to get it back to stock.
I was able to tune the car back to stock before driving it the dealership.
They replaced the control module, which one they didnt say and I didnt ask.
I didnt tell the dealership that I was tuning the car and thats how it hapend.
Or maybe not? Do you think the programmer had something to do with the module.
Can you please tell me where does the software from the programmer gets to be stored.
After they changed the module I reprogrammed the car again and 2 month later the car got stuck in 4hi again and
I programmed the car back to stock and the dealership replaced the module telling me there was a foulty module.
And that was it since then, I havent programmed the truck.
I just found the repair bill and it says found 4wd not working diag. for 4wd check signal for 3wd from switch ok no out put from module to encoder motor replace the 4wd transfer case cotrol module.
    • So, my 2021 only gets radio updates, right? If that's the case, my radio is doing just fine and probably better off without any updates, especially considering the problems I've been reading about after updates were performed.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
